jorgeg73
change sd card size
Wed Jun 28, 2017 5:18 pm
Hi to all, i have reading can not find the answer to.
I have 8 GB sd card on my pi but now is full can some one tell me if i get a 16 Gb and make a image of the 8, can i burn the image on to the 16, will it work as before whit more space?
thank you
Re: change sd card size
Wed Jun 28, 2017 6:02 pm
jorgeg73 wrote:Hi to all, i have reading can not find the answer to.
thank you
If you are running Raspbian Jessie with Pixel it comes with PiClone SD Card Copier, you will need a USB SDHC Card Reader, it was discussed in this Blog from a year ago:
https://www.raspberrypi.org/blog/anothe ... -raspbian/
RPi 4B 4GB (SSD Boot)..
hommar
Wed Jun 28, 2017 6:22 pm
jorgeg73 wrote:will it work as before whit more space?
after copy (if use dd or Win32DiskImager) do:
1) run "sudo raspi-config"
2) and select option "Expand Filesystem"
3) reboot
