jaanonim
Apatche2
Thu Jun 22, 2017 10:32 am
This is the error code when installing using the command sudo apt-get install apache2 -y :
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apache2-bin armhf 2.4.10-10+deb8u7
  404  Not Found [IP: 93.93.128.193 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apache2-utils armhf 2.4.10-10+deb8u7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apache2-data all 2.4.10-10+deb8u7
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main apache2 armhf 2.4.10-10+deb8u7
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apache2/apache2-bin_2.4.10-10+deb8u7_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apache2/apache2-utils_2.4.10-10+deb8u7_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apache2/apache2-data_2.4.10-10+deb8u7_all.deb  404  Not Found [IP: 93.93.128.193 80]
E: Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/a/apache2/apache2_2.4.10-10+deb8u7_armhf.deb  404  Not Found [IP: 93.93.128.193 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Please help!
DirkS
Re: Apatche2
Thu Jun 22, 2017 12:41 pm
Run
sudo apt-get update
before trying to install a program
Oshie
Re: Apatche2
Wed Nov 22, 2017 1:14 pm
When I run:
sudo apt-get install update
I get the following error:
Reading package lists... Done
Building dependency tree
E: Unable to locate package update
DirkS
Re: Apatche2
Wed Nov 22, 2017 1:24 pm
sora03
Re: Apatche2
Thu Nov 23, 2017 12:04 pm
make sure that the Pi has connection to internet. try ping raspberrypi.org and jessie is now oldstable we now use the stretch if your pi image is old you need to reimage the Pi or just upgrade to stretch. add this to /etc/apt/sources.list
deb http://mirrordirector.raspbian.org/raspbian/ stretch main contrib non-free rpi
FLOSS enthusiast, Debian user (linux-libre)
tony1812
Re: Apatche2
Sat Nov 25, 2017 2:22 pm
From my experience, please do a clean install of Scretch from .img, don't use sudo update to Scretch, of course make sure you have internet connection.
After install Scretch, do the followings:
sudo get update
sudo get upgrade
sudo get dist-upgrade
