JongUd
Kodi error while loading shared library
Sat Jun 17, 2017 10:17 am
Hi
I was having indigo error while in kodi/exodus that I decided to update kodi using the following:
sudo apt-get update
sudo apt-get install kodi
Then I tried to run kodi and got the message below:
/usr/lib/arm-linux-gnueabihf/kodi/kodi_v7.bin: error while loading shared libraries: libbrcmGLESv2.so: cannot open shared object file: No such file or directory
Help me on this please
Doban
Re: Kodi error while loading shared library
Sat Jun 17, 2017 6:15 pm
Same problem here. (Using the Raspberrian coming on the NOOBS SD card)
Rascas
Sat Jun 17, 2017 6:28 pm
Update your systems with:
sudo apt-get update
sudo apt-get upgrade
JongUd
Sun Jun 18, 2017 6:20 am
Thanks for the help.
I did as suggested by doing below:
After the upgrade, I still get the same error message when attempting to run kodi.
It is still looking for the shared library as I mentioned in my earlier post.
Help please.
Rascas
Sun Jun 18, 2017 10:16 am
That error is because you dont have a recent kernel installed. Update, reboot and try again.
JongUd
Sun Jun 18, 2017 10:58 pm
I wonder if I did it correctly.
I tried the following commands:
sudo apt-get update
reboot
kodi
Still got the same error.
Next:
sudo apt-get update
reboot
kodi
And a number of combination with no success.
Is it possible to know the commands to do?
Thanks for being patient with me.
Rascas
Mon Jun 19, 2017 9:05 am
JongUd wrote:I wonder if I did it correctly.
sudo apt-get update
reboot
kodi
Next:
sudo apt-get update
reboot
kodi
Thats basically that:
sudo apt-get update
To start Kodi run:
kodi
Or start it via the icon on Pixel Desktop menu.
You need to set GPU ram to at least 160 MB for 1080p playback, the recommended for Pi 2 and 3 is 256 MB. You have an option for that in raspi-config or in rc-gui on Pixel Desktop.
If it still doesn't work post here the errors exactly like they appear.
JongUd
Wed Jun 21, 2017 9:40 am
Still not working
Missing libbrcmGLESv2
Error message below:
I made some searches. It is saying likely kernel/OS did not update and talking about locale.
Unfortunately I do not know how or the commands to use. Updating OS packages and kernel.
JongUd
Fri Jun 23, 2017 9:34 am
Please help if this will update the missing file and which of the command I should be using.
sudo apt-rpi-update
Or
sudo apt-get rpi-update
I am a newbie with this and does not really know much.
Rascas
Fri Jun 23, 2017 1:10 pm
JongUd wrote:Please help if this will update the missing file and which of the command I should be using.
sudo apt-rpi-update
Or
Just do like I explained above. If You get any error (most likely, because it is the recommended way) post it here and we may help you.
peutch
Sun Sep 03, 2017 5:29 pm
I had the same problem on an up-to-date Pi3 and solved it by installing libraspberrypi0
sudo apt-get install libraspberrypi0
Hope this helps people with similar issue.
mgmaqueda
Tue Nov 07, 2017 10:38 pm
I just registered to say I had the same problem and this last solution from peutch is the only thing that really solved it.
Thank you!
streetboyz27
Thu Nov 16, 2017 6:23 pm
Damn! It Works for me. Thanks bro ;)
disco_disco
Fri Nov 17, 2017 10:13 pm
Hey guys,
Same problem here - the only exception is that the file missing is libmicrohttpd. Can't install it using "sudo apt-get install" - the error is "Can't locate the package". Any ideas on how to solve this?
Thanks in advance!
Rascas
Fri Nov 17, 2017 11:08 pm
Are you guys really using stock raspbian or raspbian lite? libraspberrypi0 isn't a Kodi dependency but it should be already installed with it. libmicrohttpd is a Kodi dependency it should be automatically installed when you install kodi. If not, you might have broken dependencies, using extra repos which collide with raspbian ones or not using stock raspbian at all...
It would help if you post the complete output of what appears when you install Kodi.
BrotherGabriel
Tue Dec 19, 2017 2:30 pm
Just signed up to say thanks - Had the problem as well and apt-get installing the library fixed it - I was definitely using a recently upgraded and as far as I know* fully "official" jessie raspbian so I'd suggest it's a real problem.
(* I'm a Debian sysadmin in the day job so like to pretend to know a bit about what I'm doing :) )
Who is online
Users browsing this forum: rhubarbdog and 30 guests
