sanglems
Using Self-signed certificate.
Thu Jun 15, 2017 2:11 am
hi.
I have a system where the sensors' data get stored on memory stick and when the I access it over browser it reads that data and show it over. Now I have to make the system secured for which I am trying to use self-signed SSL certificate.
I got the certificate using:
openssl req -x509 -newkey rsa:4096 -keyout key.pem -out cert.pem -days 365 -nodes
And my code looks like :
import socket, ssl, os
context = ssl.create_default_context(ssl.Purpose.CLIENT_AUTH)
context.load_cert_chain(certfile="cert.pem", keyfile="key.pem")
Host=' '
PORT=443
bindsocket = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
bindsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
bindsocket.bind((HOST,PORT))
bindsocket.listen(5)
while True:
    newsocket, fromaddr = bindsocket.accept()
    connstream = context.wrap_socket(newsocket, server_side=True)
    data = connstream.recv(1024)
    print data
   //code to read from memory stick and sendall(response)
   newsocket.close()
whenever I try to access the server over browser it gives "This site can't provide a secure connection. IP******* sent a invalid response. ERR_SSL_PROTOCOL_ERROR".
I tried turning off firewall. Also tried to change the code bit here n there but cannot make it work.
I also tried to make the certificate trusted using:https://unix.stackexchange.com/question ... usted-list
But same error message.
I am very new to all the things getting used here. Any help will be really appreciated.
Thank you.
raspeyote
Re: Using Self-signed certificate.
Wed Jan 03, 2018 7:39 am
Is this for a web server? I got the same error in my browser because I hadn't configured Apache correctly.
