PierrevHeumen
Use Pi as Firewall
Fri Jun 09, 2017 12:46 pm
I'am very new of using a Raspberry Pi, last weekend i installed Pi-Hole on the one i have at home and that is working great. But can i use the same (or other Pi) as a Firewall
epoch1970
Re: Use Pi as Firewall
Sat Jun 10, 2017 10:13 am
A Pi can work as a firewall, only not too fast. With Linux you can use iptables or any package built upon that.
AFAIK BSD hardware support for Pi 3 is not complete but I believe one day you'll be able to install something like OPNSense for Pi and get an awesome perimeter firewall for your devices network.
Performance: I would say Pi 3 can switch between networks at about 30mbps sustained. It is IO bound, not CPU bound (at all). As usual wifi performance will be lower than Ethernet.
So you can consider it has wire speed performance if the Pi switches traffic to/form an average speed DSL link, or to/from a small net of low-power devices. If you want it to switch between 2 100mpbs or giga LANs, you will be disappointed; look for specialized hardware instead.
tarjei99
Fri Aug 25, 2017 7:29 am
You can try downloading FreeBSD for the RPI3 or RPI2 from http://www.raspbsd.org/.
You could try to install either opnSense or pfSense on that. It might be convoluted. Including having to rename kernels before rebooting after installing. pfSense uses parts from HardenedBSD to harden the kernel. I'm unsure what opnSense does.
It might not be easy until either of these supports the RPI officially with an image.
jahboater
Fri Aug 25, 2017 7:44 am
And use a USB ethernet adapter which will give over 3x performance compared to the ethernet port which should give around 95Mbits/sec with iperf.
$ iperf -c pi
Client connecting to pi, TCP port 5001
TCP window size: 85.0 KByte (default)
[  3] local 192.168.0.5 port 38516 connected with 192.168.0.80 port 5001
[ ID] Interval       Transfer     Bandwidth
[  3]  0.0-10.0 sec   380 MBytes   318 Mbits/sec
epretorious
Mon Feb 25, 2019 9:43 pm
FreeBSD-12-RELEASE supports the Raspberry Pi.You can download it from the FreeBSD repositories:
RPi B
https://download.freebsd.org/ftp/releas ... AGES/12.0/
RPi 2
RPi 3
OpenWRT also supports RPi - It supports RPi several of the different Pi models:
https://openwrt.org/toh/raspberry_pi_fo ... spberry_pi
HTH,
Eric Pretorious,
Portland, Oregon
epretorious
Mon Feb 25, 2019 9:52 pm
...use a USB ethernet adapter which will give over 3x performance compared to the ethernet port which should give around 95Mbits/sec with iperf.
Thanks, Jeremy!
I'm curious about your results:
  • IIUC: The on-board FastEthernet NIC is connected via the USB bus. Why would a USB-Ethernet adapter provide better throughput than the on-board NIC?
  • Is there a particular adapter that works better than the others?
TIA,
Eric Pretorious,
Portland, Oregon
Mon Feb 25, 2019 10:25 pm
Thanks, Jeremy!
TIA,
Eric Pretorious,
Portland, Oregon
The post you are responding to is out of date as we now have a 3B+, but for various test results see:
https://www.jeffgeerling.com/blogs/jeff ... networking
Retired disgracefully.....
