matthewkeogh50
Setting default shell colours for a new user
Sat May 06, 2017 4:19 pm
Hi all,
I've just picked up my first raspberry pi for use as a home media server. I am running raspbian jessie lite (https://www.raspberrypi.org/downloads/raspbian/) I've enabled shh and created a new user for myself... but when logging in via kitty the original pi user has nicely formatted colours for the directories and files etc, where as the user I created, everything is black
pi user
matthew user (which was created using "useradd matthew")
Could anyone please advise how I get the "matthew" account to be like the "pi" account in terms of colours.
Thanks.
MaxK1
Re: Setting default shell colours for a new user
Sun May 07, 2017 8:45 am
I think you'll find everything you need in /home/pi/.bashrc (Yes, there is a leading dot in the file name)
You could simply copy that to /home/mattew and change the owner or create a new /home/matthew/.bashrc with just the bits you want.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
matthewkeogh50
Sun May 07, 2017 10:30 am
Thanks MaxK1
It needed both .bashrc and .profile
MaxK1
Sun May 07, 2017 12:21 pm
Good catch.
