Desertbum
Time synchronization
Sun Sep 23, 2012 4:42 pm
Hello all,
this is my first post. I try to set up my pi but have problems with the setting time.
As I understand ntp is running "out of the box".
However my pi does not connect to a NTP-server.
Here my ntp-conf (unchanged):
# /etc/ntp.conf, configuration for ntpd; see ntp.conf(5) for help
driftfile /var/lib/ntp/ntp.drift
# Enable this if you want statistics to be logged.
#statsdir /var/log/ntpstats/
statistics loopstats peerstats clockstats
filegen loopstats file loopstats type day enable
filegen peerstats file peerstats type day enable
filegen clockstats file clockstats type day enable
# You do need to talk to an NTP server or two (or three).
#server ntp.your-provider.example
# pool.ntp.org maps to about 1000 low-stratum NTP servers.  Your server will
# pick a different set every time it starts up.  Please consider joining the
# pool: <http://www.pool.ntp.org/join.html>
server 0.debian.pool.ntp.org iburst
server 1.debian.pool.ntp.org iburst
server 2.debian.pool.ntp.org iburst
server 3.debian.pool.ntp.org iburst
# Access control configuration; see /usr/share/doc/ntp-doc/html/accopt.html for
# details.  The web page <http://support.ntp.org/bin/view/Support/AccessRestrictions>
# might also be helpful.
# Note that "restrict" applies to both servers and clients, so a configuration
# that might be intended to block requests from certain clients could also end
# up blocking replies from your own upstream servers.
# By default, exchange time with everybody, but don't allow configuration.
restrict -4 default kod notrap nomodify nopeer noquery
restrict -6 default kod notrap nomodify nopeer noquery
# Local users may interrogate the ntp server more closely.
restrict 127.0.0.1
restrict ::1
# Clients from this (example!) subnet have unlimited access, but only if
# cryptographically authenticated.
#restrict 192.168.123.0 mask 255.255.255.0 notrust
# If you want to provide time to your local subnet, change the next line.
# (Again, the address is an example only.)
#broadcast 192.168.123.255
# If you want to listen to time broadcasts on your local subnet, de-comment the
# next lines.  Please do this only if you trust everybody on the network!
#disable auth
#broadcastclient
When I use ntpq to check which server is contacted I get only my router :
ntpq -p
pluggy
Re: Time synchronization
Sun Sep 23, 2012 6:38 pm
Do you have a working internet connection ?. The NTP just works usually.
Desertbum
Sun Sep 23, 2012 8:43 pm
...sorry I did not finish my first post (newbee :oops: )
When I check with
ntpq -p
I only get my router
    remote           refid      st t when poll reach   delay   offset  jitter
 fritz.box       .INIT.          16 u    -   64    0    0.000    0.000   0.000
But for installing programs and updates I have perfect internet connection.
My thought was a mistake in the ntp.conf.
Can you help?
Desertbum
LBS
Thu Jan 31, 2013 8:35 am
I had the same problem. The syslog indicated problems with the 'restrict' lines in ntp.conf, so I tried without;
#restrict 127.0.0.1
#restrict ::1
/> service ntp restart
Problem solved
