micksulley
How to set time/date without internet
Tue May 02, 2017 2:01 pm
I know this sounds a bit odd, but I want to disable time/date setting and update from the internet and do it manually. The reason is that I am developing an alarm clock (with various other features) based on a Pi Zero, and I want it to be usable if there is no internet connection. The development Pi is running headless, development on my desktop, so I cannot just disable the network.
I thought it would be easy, but don't really know how to do it! Ideas, suggestions?
Mick
Re: How to set time/date without internet
Tue May 02, 2017 2:05 pm
micksulley wrote:I know this sounds a bit odd, but I want to disable time/date setting and update from the internet and do it manually. The reason is that I am developing an alarm clock (with various other features) based on a Pi Zero, and I want it to be usable if there is no internet connection. The development Pi is running headless, development on my desktop, so I cannot just disable the network.
Mick
Maybe something like this ???
https://shop.pimoroni.com/products/adaf ... spberry-pi
Retired disgracefully.....
......to a more gentile life !
micksulley
Tue May 02, 2017 2:11 pm
No sorry, what I meant was how to disable internet update, so I can let the user set it, just like a standard digital alarm clock.
RaTTuS
Contact: Twitter YouTube
Tue May 02, 2017 2:35 pm
you use the command date
i.e.
sudo date -s 2017-02-05 15:30:0
Covfefe
micksulley
Tue May 02, 2017 3:06 pm
Thanks.
I had to put the time date in quotes
sudo date -s '2017-02-05 15:30:00'
but it does the job.
W. H. Heydt
Tue May 02, 2017 3:27 pm
I have a Pi "travel alarm", and--yes--an internet connection isn't always available.
Two points...first, you don't need to disable NTP in order to set the date manually when there is no internet connection. That way, when there *is* an internet connection, it will set itself automatically. Second...if you add an RTC to your Pi, it will get the time from that when it boots (and if an internet connection is available, it will update with a more accurate time). On a Pi0 you will need to find a way to connect the RTC. One way is to add the header pins the RTC needs. Another is to solder wires from the RTC board to the GPIO holes on the Pi0. (On the one Pi0 I have with an RTC, I have used the former method.)
jmsbc
Tue Oct 10, 2017 6:52 pm
I am able to set the date and time using the above example. However, if I manually set the date/time to an earlier time (without internet) and reboot, it will not save the date/time I entered because it was earlier than what it was previously set to.
How do I bypass this internal check?
