Super-Nathan
Force Raspi-config to run at next boot
Sun Sep 23, 2012 8:56 am
I am working on making a distro spin for Raspi and I would like to be able to distribute the image so that raspi-config is set to run at the first boot, like in Rasbian.
So, uhh, how would on go about doing so?
echo "Something Useful" > /dev/null
RaTTuS
Contact: Twitter YouTube
Re: Force Raspi-config to run at next boot
Sun Sep 23, 2012 9:17 am
put something in the /ect/rc?.d locations that do the stuff then remove the script [or change the runlrevel values on teh script]
Covfefe
Super-Nathan
Tue Oct 09, 2012 2:54 am
The secrets are this code which is a more documented version of the original. The original can be found at http://github.com/asb/raspi-config
#!/bin/sh
# Part of raspi-config http://github.com/super-nathan/raspi-config
# See LICENSE file for copyright and license details
# Should be installed to /etc/profile.d/raspi-config.sh to force raspi-config
# to run at initial login
# You may also want to set automatic login in /etc/inittab on tty1 by adding a
# line such as:
# 1:2345:respawn:/bin/login -f root tty1 </dev/tty1 >/dev/tty1 2>&1 # RPICFG_TO_DISABLE
# If you are trying to make this run on boot for a machine that has already been configured,
# then if you follow all the above instructions you will still be booted into an X session.
# If you <ctlr>+<alt>+<f1> you will find the raspi-config there ready to run.
# In order to boot straight into Raspi-config you must disable lightdm with
# $ sudo update-rc.d lightdm disable
# Then when you reboot the machine, you will be sent straight into the config.
if [ $(id -u) -ne 0 ]; then
  printf "\nNOTICE: the software on this Raspberry Pi has not been fully configured. Please run 'sudo raspi-config'\n\n"
else
  raspi-config
  exec login -f pi
fi
