I have a 1280x320 pixels ultra wide LCD. Is it possible to have a custom resolution for this to make it work correctly connected via HDMI?
Thank you.
Custom resolution for 1280x320 LCD
Re: Custom resolution for 1280x320 LCD
I've done this but it doesn't output anything:
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1280 320 60 6 0 0 0
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
You have not stated how the LCD is connected or even a Manufacture / Model, is it a secret ??matinzk wrote:I've done this but it doesn't output anything:
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
The information is out there....you just have to let it in.
No it's not a secret!fruitoftheloom wrote:You have not stated how the LCD is connected or even a Manufacture / Model, is it a secret ??matinzk wrote:I've done this but it doesn't output anything:
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
Chinese manufacturer and it's connected via HDMI.
Thank you.
That being a rather...unusual...resolution, can we have a link to it?matinzk wrote: Chinese manufacturer and it's connected via HDMI.
Is there a possibility to set he resolution to spill out? Just to elaborate; when I set the resolution to 1280x640 (double the height) it works fine but the picture is shrunk. If we could set it so it shows 1280x640 then it works for what we need it to.
Any help is appreciated.
Thank you.
Thank you.
So it has a converter board between the HDMi and Screen ???matinzk wrote:Is there a possibility to set he resolution to spill out? Just to elaborate; when I set the resolution to 1280x640 (double the height) it works fine but the picture is shrunk. If we could set it so it shows 1280x640 then it works for what we need it to.
Thank you.
Yes it's got its own controller with an HDMI input.fruitoftheloom wrote:So it has a converter board between the HDMi and Screen ???matinzk wrote:Is there a possibility to set he resolution to spill out? Just to elaborate; when I set the resolution to 1280x640 (double the height) it works fine but the picture is shrunk. If we could set it so it shows 1280x640 then it works for what we need it to.
Thank you.
Therefore for some reason the Controller Board is not reading the HDMi output of the RPi and translating that to the Sceen, so your Raspberry Pi is working as it should..matinzk wrote:Yes it's got its own controller with an HDMI input.fruitoftheloom wrote:So it has a converter board between the HDMi and Screen ???matinzk wrote:Is there a possibility to set he resolution to spill out? Just to elaborate; when I set the resolution to 1280x640 (double the height) it works fine but the picture is shrunk. If we could set it so it shows 1280x640 then it works for what we need it to.
Thank you.
It does output picture if I set the resolution at 1280x640 for example but it shrinks it. Hence why I asked if it's possible to make it spill out? Anything we can do in the config.txt file to achieve this?
Thank you.
Thank you.
I set the resolution to 1920x480 pixels and it now outputs the image correctly. I can work with this.
I also have another LCD from the same manufacturer. 12.3" wide. Resolution is 1920x720 pixels. When I set the following in the config.txt file I get some white stuff at the bottom of the screen. Any ideas why?
This is my config.txt file contents:
Here is the image of what the output looks like:
The manufacturer also has provided the following advising to set the HDMI to, but I'm unsure of how to set this up in the config.txt file.
Any help is appreciated. Thank you.
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 1920 720 60 6 0 0 0
#define Vclk_MHZ 132
#define LCD_XSIZE 1920
#define LCD_YSIZE 720
#define ADJHIGHT LCD_YSIZE
#define LCD_BPP 16
#define FRAME_RATE 60
#define LCD_ROTATE 0
#define HBPD 110
#define HFPD 8
#define HSPW 8
#define VBPD 10
#define VFPD 10
#define VSPW 4
