After this i installed 'pulseaudio'.
After i change the volume by alsamixer the audio output is stuttering?
Is there a other way to do this, because i use pulseaudio as rtp-receiver.
After the volume change the device is out of sync with the others.
/etc/pulse/system.pa (client)
load-module module-udev-detect tsched=0
load-module module-rtp-recv sap_address=10.10.10.92
default-sample-rate = 48000
resample-method = src-sinc-fastest
default-fragments = 8
default-fragment-size-msec = 10
