Luara
Changing the default pin configuration
Tue Apr 18, 2017 3:42 pm
Hi, guys
I'm using the Raspberry Pi Compute Module 3 and I need to change the configuration of the pins 46 and 48 (GPIO32 and GPIO33).
I'm trying to follow this guide: https://www.raspberrypi.org/documentati ... uration.md
But when I try to put "sudo dtc -I dts -O dtb -o /boot/dt-blob.bin dt-blob.dts", I receive: FATAL ERROR: Couldn't open "dt-blob.dts": No such file or directory
I don't know what I have to do to solve this. Does anybody can help me, please?
(Sorry about my English)
Fisek
Re: Changing the default pin configuration
Thu Sep 20, 2018 8:57 am
I think this is related to NOOBS installation. I am also having the same issue.
Could someone explain what to do (step-by-step) if possible please?
B.Goode
Thu Sep 20, 2018 9:21 am
This (unanswered) previous question was apparently about a Compute Module.
If your question is about a conventional Raspberry Pi board it is probably unrelated to that issue.
It would be less confusing to Report your own post to a Moderator with a request that it be turned into a new standalone topic. Adding further detail about your RPi, Operating System, and what you are attempting to accomplish would also be helpful in eliciting a knowledge reply.
Maybe the NOOBS Installer is not an appropriate method for getting Raspbian installed in your circumstances?
