Page 1 of 2
GPU & CPU Temp in Fahrenheit
Posted: Sat Apr 15, 2017 12:05 pm
by Sparks135
I am using this code to show GPU Temp in Fahrenheit and CPU Temperature in Fahrenheit. How do I convert this to show both?
#!/bin/bash
# Script: my-pi-temp.sh
# Purpose: Display the ARM CPU and GPU  temperature of Raspberry Pi 2/3
# Author: Vivek Gite <www.cyberciti.biz> under GPL v2.x+
cpu=$(</sys/class/thermal/thermal_zone0/temp)
echo "$(date) @ $(hostname)"
echo "-------------------------------------------"
echo "GPU => $(/opt/vc/bin/vcgencmd measure_temp)"
echo "CPU => $((cpu/1000))'C"CENTIGRADE=$(vcgencmd measure_temp | awk -F "[=\']" '{print $2}')
FARENHEIT=$(echo "(1.8 * $CENTIGRADE) + 32" |bc)
echo temp=$FARENHEIT\'F
As you can see below the temp must be for the GPU I need it to show each.
This my output now:
GPU => temp=54.8'C
CPU => 54'C
temp=132.4'F
Re: GPU & CPU Temp in Fahrenheit
Posted: Tue Apr 18, 2017 2:00 pm
by PhilE
This is NOT a Device Tree question, so you're in the wrong forum - beginners might have been better - but here you go:
#!/bin/bash
gpu=$(/opt/vc/bin/vcgencmd measure_temp | awk -F "[=\']" '{print $2}')
cpu=$(echo "$cpu / 100 * 0.1" | bc)
cpuf=$(echo "(1.8 * $cpu) + 32" |bc)
gpuf=$(echo "(1.8 * $gpu) + 32" |bc)
echo "GPU => $gpu'C ($gpuf'F)"
echo "CPU => $cpu'C ($cpuf'F)"
I've broken into down into a few more steps for clarity.
Running it now I get:
Tue 18 Apr 13:59:01 UTC 2017 @ raspberrypi
GPU => 47.8'C (118.0'F)
CPU => 48.3'C (118.9'F)
But Fahrenheit is an antique and should die quickly. 8-)
Posted: Tue Apr 18, 2017 5:40 pm
by Sparks135
PhilE wrote:This is NOT a Device Tree question, so you're in the wrong forum - beginners might have been better - but here you go:
#!/bin/bash
Thank you that did the trick. Your method is so much cleaner. Thanks again.
Posted: Fri Jun 30, 2017 10:54 pm
by OutsourcedGuru
As someone in the states and since we still use Fahrenheit, it would be nice to have this support via raspi-config (display celsius or fahrenheit) versus a single setting.
Posted: Sat Jul 01, 2017 6:29 am
by DougieLawson
OutsourcedGuru wrote:As someone in the states and since we still use Fahrenheit, it would be nice to have this support via raspi-config (display celsius or fahrenheit) versus a single setting.
A better option would be for you to shout at your Government until they drop the use of Imperial and American units and start using ISO units for everything. I'm sure Mr. Trump would like the chaos that would cause.
Posted: Mon Jul 03, 2017 9:44 pm
by OutsourcedGuru
"Is there anyone who ever remembers
Changing their mind from the paint on a sign?
Is there anyone who really recalls
Ever breaking record off
For something someone yelled real loud one time
Oh, everyone believes
In how they think it ought to be
And they're not going easily..."
~ John Mayer - Belief lyrics
Posted: Sun May 27, 2018 12:05 am
by Jeffrey.j
#!/bin/bash
Hi. I know this is an older post but I was hoping that you could briefly explain these parts:
(Just why this one is nessessary), and why is there a “<“ here:
. Also, if I were to make this an alias, how would I do that? Thank you.
Posted: Sun May 27, 2018 1:54 am
by Paeryn
#!/bin/bash
That is a very simple awk program that splits each line from the input file into fields where fields are delimited by either an equals sign or a single quote and outputs the second field.
-F "[=\']" sets the field separator, if you give a string of more than one character then the string is a regular expression.
'{print $2}' is the awk program to run. No pattern is given so it will be applied to every line, $n means the item that is the nth field.
$(<filename) says return the contents of the file filename, here the content of that file is a string (e.g. 49388) so the variable cpu will have that string. Think of it as $(cat filename), just that bash will do it itself rather than calling cat to do it.
The temperature from that file is the temperature*1000. $(echo "$cpu / 100 * 0.1" | bc) passes the equation (using the value above) "49388 / 100 * 0.1" to the calculator program bc. It isn't just divided by 1000 because in bc the divide operator returns the quotient so 49388 / 100 will give the answer 493 (the 0.88 is discarded), this is then multiplied by 0.1 to effectively divide by a further 10 to get the answer but this time keeping the fractional part to give 49.3
Posted: Sun May 27, 2018 1:51 pm
by PhilE
That's a very detailed and accurate answer. All I would add is the reason for the awk command.
The output from "vcgencmd measure_temp" is of the form "temp=48.3'C", so a lazy (laziness can be a virtue) way of extracting the number is to split the input at the "=" and the "'", and keep the second element.
Posted: Sun May 27, 2018 7:14 pm
by Jeffrey.j
#!/bin/bash
Thank you so much this really helps! Also is there a way I could make this into an alias?
Posted: Sun May 27, 2018 7:17 pm
by PhilE
Yes, in one form or another, but what advantage do you think that would have?
Posted: Sun May 27, 2018 10:28 pm
by Jeffrey.j
Well I plan on checking the temperature every once in a while, so instead of typing this all in/copy and pasting it, I could just type in a simple command that is an alias to simplify it.
Update: I played around with it and I figured out how to do it :D! Thank you for the help though.
Posted: Wed Aug 22, 2018 4:05 pm
by JeffZ123
Thanks for the script!
Also simple thing probably everyone knows, but you can use the watch command to monitor the output in a dedicated window (where the script above is put in the file "temperature.sh") like so:
(Ctrl-C to exit)
[email protected]:~ $watch temperature.sh
Every 2.0s: ./temperature.sh        retropie: Wed Aug 22 16:04:04 2018
Wed Aug 22 16:04:04 UTC 2018 @ retropie
GPU => 41.9'C (107.4'F)
CPU => 41.3'C (106.3'F)
See the watch man page for how to configure things like output frequency (--interval) etc.
Posted: Wed Dec 26, 2018 9:29 pm
by drushtx
Seriously? This is permissible? May I take political potshots at Mrs. May, as well or would the author prefer to "educate" me with an instructive baseball bat?
Posted: Wed Dec 26, 2018 10:08 pm
by PhilE
Dougie is skating on very thin ice with that signature of his.
Posted: Thu Dec 27, 2018 12:51 am
by Greg Erskine
Would anyone care?
He is NOT allowed to figuratively "use" his "educational baseball bat" on this forum. Are you trying to bait him? :mrgreen:
Posted: Sat Oct 19, 2019 11:07 pm
by OutsourcedGuru
Well, you saw my response earlier
An operating system if it's released to the world should attempt to make the world's citizens feel included. We add locales, default languages, we format references to money and dates correctly for each person. We even accommodate the right-to-left sort of languages on displays and consoles. I should know since I've recently written a program which supports many different languages/locales and everything formats as expected for each.
That said, there's nothing to suggest that Celsius is the only way the world communicates heat. It's an exceedingly-simple calculation. The omission in Raspbian of the configurable option seems like an oversight.
Is this being considered or not as a feature?
Posted: Sun Oct 20, 2019 12:15 am
by scruss
I think it's only likely to happen if someone upstream ports it; that is, no-one at the Raspberry Pi/Raspbian teams have time. Since the current maintainer of lxpanel is in Ukraine, they're probably not going to do it themselves either. So submit patches or it's unlikely to happen.
Language, script and locale are a part of national identity. Being the only country using weird old units? That's a choice.
Posted: Sun Oct 20, 2019 3:52 pm
by DougieLawson
The USA is in a group of three that use non-metric things.
The rest of the world is either fully metric or stupidly stuck in their 50 year transition from imperial (feet/inches/yards/furlongs/miles, pounds/ounces, inHg, etc) to mostly metric - like the silly Untied Kingdom. I was taught both systems at school 50 years ago.
I liked the way Ireland changed speed limits first then changed distances between towns (the UK could follow that example).
We also need to accept that 500ml of beer/milk is close enough to 568ml to not adversely affect the price. It's obvious the quantity per unit will change, the price per unit won't. I'll rely on Wetherspoons doing the right thing with a "metric pint".
There still remains no value in the Fahrenheit temperature regardless of metrication.
Posted: Sun Oct 20, 2019 6:38 pm
by jamesh
All the docs use centigrade, all posts on forums use centigrade. Having something report in fahrenheit would be massively confusing.
Posted: Sun Oct 20, 2019 6:44 pm
by gordon77
a "metric pint".
:lol: a metric pint, that's a new concept to confuse.
Posted: Sun Oct 20, 2019 8:53 pm
by scruss
… Having something report in fahrenheit would be massively confusing.
You could sell a lot of CPU fans to the unsuspecting, though …
Posted: Sun Oct 20, 2019 9:03 pm
by PeterO
a "metric pint".
At the time we went metric my late Father owned a Joinery business. Sometimes I used to go to work with him during my school holidays.
I can remember the timber merchants would sell "metric yards" of wood (which were 39 inches if I remember correctly). :lol:
PeterO
Posted: Sun Oct 20, 2019 10:53 pm
by davidcoton
A "metric foot" is 300mm, still used in the building trade as a standard unit (though the name is not often remembered).
It is a unit aligned with the metric system but approximately the same as an imperial foot.
So I suspect a "metric yard" may be 900mm (35.5") -- timber is still commonly sold in multiples of 900mm.
39" is also possible, as that converts to about 990mm, but the logic there is reversed (an imperial measurement approximating to 1m),
Network cable is commonly supplied with a length of 305m (1000ft) on a drum.
Posted: Mon Oct 21, 2019 8:08 am
by rpdom
I still find model railways amusing.
They work in scales like 4mm = 1foot.
