command line version of piclone?
My query in short: Is there a command line version of piclone?
(see: https://www.raspberrypi.org/blog/anothe ... -raspbian/ scroll down to SD card copier)
I have a 'headless' PI running Jessie Lite, so I can't run piclone from the UI. Via SSH I can access the device.
(Edit: it's piclone, not picopy)
Re: command line version of picopy?
Yes. it's called dd and is a standard *nix tool and how we used to copy .img files to SD cards back in the old days.
picopy ("piclone") isn't the same as dd
dd is a direct byte for byte copy - so resulting .img would be huge, and also can't copy to smaller sd cards
piclone first sets up partitons, then does a file based copy - so can move a 32GB SD card install to 8 GB etc..
In the github for piclone, there is the original command line script here:
https://github.com/raspberrypi-ui/piclo ... src/backup
Re: command line version of piclone?
Thanks Mike,
I corrected the name of the tool.
The link you provided looks to be what I needed
I pasted the above code into a file I named sdclone & tried to run it. I got.....
root@raspberrypi:/home/pi# bash sdclone
umount: 9: mountpoint not found
umount: 8: mountpoint not found
umount: 7: mountpoint not found
umount: 6: mountpoint not found
umount: 5: mountpoint not found
umount: 4: mountpoint not found
umount: 3: mountpoint not found
umount: 2: mountpoint not found
umount: 1: mountpoint not found
dd: failed to open ‘’: No such file or directory
Error: Could not stat device mklabel - No such file or directory.
Retry/Cancel?
Clearly my simple minded approach has missed some detail. Is there a simple guide for how to get piclone working on Jessie lite where there is no startx or pixel?
Retry/Cancel?
The script requires the target device on the command line
Make sure to get /dev/sdx right, or (as usual) you could wipe out your pi...
(oh, and will probably need to be run as root too)
sdclone /dev/sdx
Thnx for the tip, any idea how to fix the 'operation not permitted' errors?
root@raspberrypi:/home/pi# bash sdclone /dev/sda
umount: /dev/sda9: mountpoint not found
umount: /dev/sda8: mountpoint not found
umount: /dev/sda7: mountpoint not found
umount: /dev/sda6: mountpoint not found
umount: /dev/sda5: mountpoint not found
umount: /dev/sda4: mountpoint not found
umount: /dev/sda3: mountpoint not found
umount: /dev/sda2: not mounted
1+0 records in
1+0 records out
512 bytes (512 B) copied, 0.0219021 s, 23.4 kB/s
Information: You may need to update /etc/fstab.
mkfs.fat 3.0.27 (2014-11-12)
mkfs.fat: /dev/sda1 contains a mounted filesystem.
‘/tmp/tmp.yDOGKpbbDU/./COPYING.linux’ -> ‘/tmp/tmp.p8jDE1pUJ8/././COPYING.linux’
cp: failed to preserve ownership for ‘/tmp/tmp.p8jDE1pUJ8/././COPYING.linux’: Operation not permitted
‘/tmp/tmp.yDOGKpbbDU/./LICENCE.broadcom’ -> ‘/tmp/tmp.p8jDE1pUJ8/././LICENCE.broadcom’
cp: failed to preserve ownership for ‘/tmp/tmp.p8jDE1pUJ8/././LICENCE.broadcom’: Operation not permitted
‘/tmp/tmp.yDOGKpbbDU/./bcm2708-rpi-b-plus.dtb’ -> ‘/tmp/tmp.p8jDE1pUJ8/././bcm2708-rpi-b-plus.dtb’
cp: failed to preserve ownership for ‘/tmp/tmp.p8jDE1pUJ8/././bcm2708-rpi-b-plus.dtb’: Operation not permitted
‘/tmp/tmp.yDOGKpbbDU/./bcm2708-rpi-b.dtb’ -> ‘/tmp/tmp.p8jDE1pUJ8/././bcm2708-rpi-b.dtb’
cp: failed to preserve ownership for ‘/tmp/tmp.p8jDE1pUJ8/././bcm2708-rpi-b.dtb’: Operation not permitted
‘/tmp/tmp.yDOGKpbbDU/./bcm2709-rpi-2-b.dtb’ -> ‘/tmp/tmp.p8jDE1pUJ8/././bcm2709-rpi-2-b.dtb’
1+0 records in
1+0 records out
I get a similar gripe when I try to use Bill Wilson's rpi-clone
Just ignore them. They're harmless. It's just the copy trying to set the ownership and permissions on the files, but the VFAT file system in /boot doesn't support them.PlanB wrote:Thnx for the tip, any idea how to fix the 'operation not permitted' errors?
- peterscargill
- Contact: Website
Interesting responses in here including the smartalec DD response. PICLONE is definitely NOT DD.
I got mountpoint not found for sda9 through 3, but that is to be expected. sda2 and 1 not found. re-reading partition table failed - resource busy, HOWEVER, it DOES seem to be working, now half way through partition 2 which begs the question why the warnings and apparent error on rereading the table?
Desktop CD Copy has always worked for me and so I've no reason to think this command line version won;t... ignoring those mountpoint warnings, is that re-read failed message is maybe important? Dialog says copy complete. Rebooted onto new SD. Works.. but that message is bugging me.
Did this on a PI2 with full Raspbian.
Regards
Peter Scargill (tech.scargill.net)
I used sdclone successfully (see github link above) and it got me out of a pickle. I have an RPi model 3A+ which has only one USB port. This enabled me to SSH in and successfully clone the current SD card.
Tips for newbies: use command lsblk which yields
- NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
sda 8:0 1 7.4G 0 disk
├─sda1 8:1 1 41.8M 0 part
└─sda2 8:2 1 7.4G 0 part
mmcblk0 179:0 0 7.4G 0 disk
├─mmcblk0p1 179:1 0 1.8G 0 part /tmp/tmp.egPTiZW7gf
├─mmcblk0p5 179:5 0 32M 0 part
├─mmcblk0p6 179:6 0 69M 0 part /boot
└─mmcblk0p7 179:7 0 5.6G 0 part /
sudo ./sdclone /dev/sda /dev/macblk0
- HawaiianPi
Shouldn't that be mmcblk0 (not macblk0)?dckornbluh wrote: ↑Sat Dec 15, 2018 11:14 pmThen I used this command:Code: Select all
sudo ./sdclone /dev/sda /dev/mmcblk0
Re: command line version of piclone? cloned card does not boot
I follow steps below and successfully clone my sd card. However, the cloned card does not boot. Please help!
dckornbluh wrote: ↑Sat Dec 15, 2018 11:14 pmI used sdclone successfully (see github link above) and it got me out of a pickle. I have an RPi model 3A+ which has only one USB port. This enabled me to SSH in and successfully clone the current SD card.
Tips for newbies: use command lsblk which yieldsThen I used this command:
└─mmcblk0p7 179:7 0 5.6G 0 part /Code: Select all
I know this thread has been silent for a while, but I hope I can get advice on some small details....
I am usually working with non-GUI RPi units and it is a PITB making backup copies of the SD-card on a headless RPi only accessing it via SSH.
So I used the link above to retrieve the backup script from github, here renamed to sdclone.
When I looked inside the script I could not see it using more than one argument and that is the target drive name, so the correct usage should be:
The code sets the src and dst variables internally like this:
What does this in fact do?
They are used later in the code in mount, cp and umount operations:
I am curious how the setting works to wind up with the correct values....
src=$(mktemp -d)
dst=$(mktemp -d)
sudo mount $1$pnum $dst
sudo mount /dev/mmcblk0p$pnum $src
sudo cp -axv $src/. $dst/.
sudo umount $dst
sudo umount $src
Bo Berglund
Sweden
Sweden
ObSnarkiness: "man mktemp"The code sets the src and dst variables internally like this:What does this in fact do?Code: Select all
src=$(mktemp -d) dst=$(mktemp -d)
It creates a guaranteed unique directory under /tmp and returns the name of the new directory.
BTW, earlier up in your post, you say:
I'm pretty sure the "sudo" is unnecessary. I'm basing this on the fact that most of the script's commands that need it seem to be preceded withsudo ./sdclone /dev/sda
Note that seeing
GitD's list of things that are not ready for prime time:
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Loves Linux; loves to dance.
1) IPv6
2) 64 bit OSes
3) USB 3
4) Bluetooth
Correct, I just quoted the original suggestion for the command execution, but if I look closer in the script it precedes all such commands with sudo that need elevation.GlowInTheDark wrote: ↑Thu Feb 27, 2020 12:51 amBTW, earlier up in your post, you say:I'm pretty sure the "sudo" is unnecessary. I'm basing this on the fact that most of the script's commands that need it seem to be preceded with sudo on their own, so it shouldn't be necessary to sudo the script itself.sudo ./sdclone /dev/sda
Now that I can understand it I will try it out on my newly configured RPi4.
Bo Berglund
Sweden
Sweden
I just came across this command line rpi-clone on github.
Has someone here tested it and can give feedback?
It seems like it has many features like the ability to be used as a backup function with incremental updates of a base copy where only changed files are transferred.
Maybe this would be a better solution than the script discussed above?
OTOH:
The rpi-clone script is huge and does a lot of different things, maybe "keep it simple, stupid" is a valid comment here?
OTOH:
Bo Berglund
Sweden
Sweden
I went ahead and inserted an 8GB SD-card into a USB carrier and inserted it into my RPi4 where I had already put the sdclone script file into my bin dir.
I ran it using the command:
After about 20 min it was done and displayed a message concerning some fix that needed to be done to fstab.
Since I did not know what that meant I just shut down my RPi4 and switched SDcard so the clone is now in the RPi4.
But on startup nothing much happens, it does not come on line so I can access it via PuTTY (I have a boot script that posts the IP address of the RPi following boot and this does not happen.
What can I look for now?
If I switch the old SDcard back to the RPi4 it starts up OK and if I insert the USB caddy with the cloned card I get the following:
So at least the partitions on the new card looks OK. Note that I used an 8GB card when cloning from the 32 GB original since the actual used space on the card was only some 2.7 GB (it is the lite version of Raspbian Buster).
Regarding fstab, here is what it contains on the running RPi4:
I mounted the SDcard in the caddy and this is what fstab on it looks like:
How can I use this information to adjust fstab, if that is what is needed to make the RPi4 run with the cloned card?
Any advice welcome, it seems like I am almost there...
sdclone /dev/sda
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 003: ID 14cd:1212 Super Top microSD card reader (SY-T18) <== My SDcard reader
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
sudo lsblk -o UUID,NAME,FSTYPE,SIZE,MOUNTPOINT,LABEL,MODEL
UUID NAME FSTYPE SIZE MOUNTPOINT LABEL MODEL
sda 7.4G Storage_Device
8139-B4CA ├─sda1 vfat 256M
e31a2667-663c-4715-a994-bb94af77a1b7 └─sda2 ext4 7.2G
mmcblk0 28.9G
69D5-9B27 ├─mmcblk0p1 vfat 256M /boot boot
24eaa08b-10f2-49e0-8283-359f7eb1a0b6 └─mmcblk0p2 ext4 28.7G / rootfs
cat /etc/fstab
proc /proc proc defaults 0 0
PARTUUID=d9b3f436-01 /boot vfat defaults 0 2
PARTUUID=d9b3f436-02 / ext4 defaults,noatime 0 1
# a swapfile is not a swap partition, no line here
# use dphys-swapfile swap[on|off] for that
cat /mnt/sdroot/etc/fstab
Bo Berglund
Sweden
Sweden
SOLVED!Bosse_B wrote: ↑Thu Feb 27, 2020 9:59 amI just came across this command line rpi-clone on github.
OTOH:
I can report that unlike the simpler script discussed above rpi-clone actually does its job and finishes (in my case in 24 min) with a bootable target SD-card!
This is what I will use going forward to maintain a backup.
Bo Berglund
Sweden
Sweden
So... I would run the script like this?mikerr wrote: ↑Wed Apr 12, 2017 10:49 ampicopy ("piclone") isn't the same as dd
./piclone.sh > mygolden.img
In my case I keep the backed up data on a (smaller) SDcard, which is a clone of the active SDcard.
It took 24 min to create it using rpi-clone and I have verified that it is OK by running it in the RPi4.
Then I have reverted to the original SDcard and continued working on the RPi4.
Now I can back it up easily by reinserting the cloned disk in a USB carrier and then run
A few questions are shown to define what I want to do and then it rsync's my active SD onto the copy SD.
This will update the image to be again equivalent to the active disk and this time it takes just a minute or two.
So I can use this as my backup.
sudo rpi-clone sda
Bo Berglund
Sweden
Sweden
