Synaptic does work well but I have actually been having much better luck using
'apt-get' as it's more reliable. I find the Aptitude manager to be very arcane,
old school and not at all 'user-friendly'. I won't be using it at all anymore, It's
very tedious. I would not recommend Aptitude to any one. I believe it
should not be on the released image at all. It my opinion, it is a very
poor choice to use as a package manager. Plus it even looks very crude
and something from linux distros about 1999 or early 2000. It is not intuitive at all.
I have played around enough to have to re-image the SD card at least 3 times. Upon
each new image run, I update/upgrade first using apt-get.
SD cards are very picky and not always the best medium to use. Two re-images
were to correct a kernel panic caused by me not shutting down correctly (yes, you WILL
re-image a card if this isn't done properly).
On Shutdown - I have discovered that with using a hub, remove the power supply to the hub first,
then the 5v power to the pi, otherwise the hub keeps the pi powered up all by itself.
I have made progress this week - I got a wifi dongle installed successfully without having to
alter any config files. It works. Now to find a browser for the pi that actually supports HTML 5
so I can SEE Youtube videos. I give up on Flash. It is still one of the most unreliable products on the planet with regular "flash crashes" in my w7 Firefox setup. I have set the overclock to Turbo in raspi-config but have yet to experience greater speed. With the titanium metal case I have on the pi, it wicks away the heat and keeps the pi at 42 celsius all evening. Even with re-imaging and backing
up cards, Life is good. I am learning a lot.
