symeboy
Crash out of loop with sudo halt = bad?
Tue Apr 11, 2017 8:56 pm
Hi all,
I need to exit a loop and shut down on a button press, the python script below works, in that it forces a sudo shutdown directly. Is this OK or do I need to find a way to exit the loop first? Ive tried sys.exit() and various attempts using kill -SIGSTOP but neither work. Might not be a problem but because its a headless outdoor project I'd like to reduce the risk of failure.
Thanks in advance
import time
import smtplib
import sys
import os
import datetime
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BCM)
os.system("cd /home/pi/detector")
GPIO.setup(17, GPIO.IN)
def stop(self):
print "Program stopping"
GPIO.cleanup()
os.system("sudo halt")
GPIO.add_event_detect(17, GPIO.FALLING, callback=stop, bouncetime=400)
try:
while True:
s = ''.join([ch if ch != ' ' else '_' for ch in str(datetime.datetime.now())])
os.system("AUDIODRIVER=alsa AUDIODEV=hw:0,0 rec /home/pi/detector/Wavs/" + s +".wav -G sinc 13k silence 1 0.1 20% trim 0 5")
time.sleep(4)
except KeyboardInterrupt:
print "You've stopped the program by CTRL-C"
GPIO.cleanup()
print "GPIO cleanup. All done."
Re: Crash out of loop with sudo halt = bad?
Tue Apr 11, 2017 9:08 pm
If your program doesn't write any data then there's no problem tearing its legs off while it's running.
I'd use "sudo poweroff" rather than "sudo halt".
symeboy
Tue Apr 11, 2017 10:34 pm
Excellent, thankyou :mrgreen:
