Sparks135
Bought USB 16gb ssd can't see it on Mac
Fri Apr 07, 2017 9:20 pm
I bought a SanDisk 16gb mSSD PCI USB drive. I can't see it on my Mac but I can see it on my Raspberry Pi 3. I need to format it for the Raspberry Pi 3, but can't figure out how. Is there a format utility hidden? Or another way to do this? Thanks.
Re: Bought USB 16gb ssd can't see it on Mac
Fri Apr 07, 2017 9:38 pm
Sparks135 wrote:I bought a SanDisk 16gb mSSD PCI USB drive. I can't see it on my Mac but I can see it on my Raspberry Pi 3. I need to format it for the Raspberry Pi 3, but can't figure out how. Is there a format utility hidden? Or another way to do this? Thanks.
If you have instaled Raspbian Jessie with Pixel OS you can use gparted:
sudo apt-get update
sudo apt-get install gparted
http://gparted.org
Apple OSX Operating System supports FAT32 as do Linux Operating Systems.
FYI Mac and Raspberry Pi are the hardware and both need an Operating System to function...
Last edited by fruitoftheloom on Fri Apr 07, 2017 9:40 pm, edited 1 time in total.
adieu
Sparks135
Fri Apr 07, 2017 10:25 pm
sudo apt-get update
http://gparted.org
Thank you installing now. I can't figure out why I can see it on my Raspberry Pi 3 but not my Mac.
Fri Apr 07, 2017 10:54 pm
sudo apt-get update
http://gparted.org
OSX has native support for certain file systems (I am sure it is somewhere on the Apple Website), the MAC has no support as it is the hardware......
Natively most Linux Operating Systems support EXT and FAT file systems....
adieu
Sparks135
Fri Apr 07, 2017 11:58 pm
I had to do it the hard way. I put the SSD in an old mac with Mountain Lion, formated it as Mac Guid and then took a blank SD card and put both into the Pi Hub. I used the SD copy utility and copied the blank SD card to the SSD which erased and formatted ast Fat32. I then moved it back to the Mac and renamed it. I now have a functioning SSD. Now I have to figure out how to use it as the main drive. Thanks.
