naswanziq
Phone to RPI3 inbuilt wifi
Wed Mar 29, 2017 1:33 pm
How do I use my smartphone to connect/detect a Raspberry Pi 3 inbuilt wifi?
I dont need the internet. Just the connection between these 2 through wifi.
Any help will be much appreciated. Thank you! :D :)
The Monkey
Re: Phone to RPI3 inbuilt wifi
Wed Mar 29, 2017 2:21 pm
Well I know that there is a hotspot thing with iOS, but not entirely sure with android otherwise I'd say connect it to internet first.
tweak42
Wed Mar 29, 2017 7:52 pm
naswanziq wrote:How do I use my smartphone to connect/detect a Raspberry Pi 3 inbuilt wifi?
Well you can setup your smartphone as a hotspot and direct the Pi to connect to it, or you can do the revers and setup the Pi as a hotspot and connect your phone to it.
https://www.raspberrypi.org/documentati ... s-point.md
naswanziq
Thu Mar 30, 2017 10:29 am
Thank you for the heads up! I ran into a problem though when running command;
sudo service dhcpcd restart
sudo ifdown wlan0
sudo ifup wlan0
What I got was,
for command "sudo ifdown wlan0";
ifdown: interface wlan0 not configured
for command "sudo ifup wlan0";
RTNETLINK answers: File exists
Failed to bring up wlan0
Thank you!
tweak42
Sun Apr 02, 2017 7:06 am
naswanziq wrote: Thank you for the heads up! I ran into a problem though when running command;
sudo ifdown wlan0
sudo ifup wlan0
What I got was,
Thank you!
It sounds like either wlan0 is not assigned a static IP or dhcpd is still controlling that interface.
