hollipl
Quake 3 compile fails on Pi 3 B
Tue Mar 28, 2017 9:03 am
I have tried 15 different tutorials for compiling quake 3, watched 3 different youtube videos, I'm following the process precisely and I'm also quite computer literate, so I'm not making a newbie mistake, but compiling fails every single time. Here is the console outplease. Help is appreciated.
make[2]: Entering directory '/home/pi/quake3'
LD build/release-linux-arm/ioq3ded.arm
CC code/client/cl_main.c
CC code/qcommon/msg.c
CC code/qcommon/net_chan.c
/usr/bin/ld: cannot find -lvchostif
/usr/bin/ld: cannot find -lvcfiled_check
/usr/bin/ld: cannot find -lbcm_host
/usr/bin/ld: cannot find -lkhrn_static
/usr/bin/ld: cannot find -lvchiq_arm
/usr/bin/ld: cannot find -lopenmaxil
/usr/bin/ld: cannot find -lEGL
/usr/bin/ld: cannot find -lGLESv2
/usr/bin/ld: cannot find -lvcos
collect2: error: ld returned 1 exit status
Makefile:1657: recipe for target 'build/release-linux-arm/ioq3ded.arm' failed
make[2]: *** [build/release-linux-arm/ioq3ded.arm] Error 1
make[2]: *** Waiting for unfinished jobs....
code/qcommon/net_chan.c: In function ‘Netchan_Process’:
code/qcommon/net_chan.c:306:8: warning: variable ‘qport’ set but not used [-Wunused-but-set-variable]
int qport;
code/client/cl_main.c: In function ‘CL_ChangeReliableCommand’:
code/client/cl_main.c:463:6: warning: variable ‘r’ set but not used [-Wunused-but-set-variable]
int r, index, l;
code/client/cl_main.c: In function ‘CL_GetServerStatus’:
code/client/cl_main.c:3428:18: warning: variable ‘serverStatus’ set but not used [-Wunused-but-set-variable]
serverStatus_t *serverStatus;
make[2]: Leaving directory '/home/pi/quake3'
Makefile:981: recipe for target 'targets' failed
make[1]: *** [targets] Error 2
make[1]: Leaving directory '/home/pi/quake3'
Makefile:975: recipe for target 'release' failed
make: *** [release] Error 2
