darkbibble
ds3231 clock temperature sensor access?
Mon Mar 27, 2017 1:57 pm
according to the spec sheet for the ds3231 clock it has a internal temprature sensor. is there any way to access this via the i2c??
Q; How many Windows users does it take to fix a Linux problem??
A; Whats a Linux problem
Re: ds3231 clock temperature sensor access?
Mon Mar 27, 2017 2:21 pm
What does i2cdetect -y 1 show?
What does ls -la /sys/bus/i2c/devices/1-0068/* show? There might be a pseudo filesystem file there for the temperature sensor registers.
darkbibble
Mon Mar 27, 2017 2:34 pm
 pi@pi-top:~ $ i2cdetect -y 1
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- 0b -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- 73 -- -- -- --
pi@pi-top:~ $ ls -la /sys/bus/i2c/devices/1-0068/*
lrwxrwxrwx 1 root root    0 Mar 27 15:32 /sys/bus/i2c/devices/1-0068/driver -> ../../../../../../bus/i2c/drivers/rtc-ds1307
-r--r--r-- 1 root root 4096 Mar 27 15:32 /sys/bus/i2c/devices/1-0068/modalias
-r--r--r-- 1 root root 4096 Mar 27 15:32 /sys/bus/i2c/devices/1-0068/name
lrwxrwxrwx 1 root root    0 Mar 27 15:32 /sys/bus/i2c/devices/1-0068/of_node -> ../../../../../../firmware/devicetree/base/soc/i2c@7e804000/ds3231@68
lrwxrwxrwx 1 root root    0 Mar 27 14:09 /sys/bus/i2c/devices/1-0068/subsystem -> ../../../../../../bus/i2c
-rw-r--r-- 1 root root 4096 Mar 27 14:09 /sys/bus/i2c/devices/1-0068/uevent
/sys/bus/i2c/devices/1-0068/power:
total 0
drwxr-xr-x 2 root root    0 Mar 27 15:32 .
drwxr-xr-x 4 root root    0 Mar 27 14:09 ..
-rw-r--r-- 1 root root 4096 Mar 27 15:32 autosuspend_delay_ms
-rw-r--r-- 1 root root 4096 Mar 27 15:32 control
-r--r--r-- 1 root root 4096 Mar 27 15:32 runtime_active_time
-r--r--r-- 1 root root 4096 Mar 27 15:32 runtime_status
-r--r--r-- 1 root root 4096 Mar 27 15:32 runtime_suspended_time
/sys/bus/i2c/devices/1-0068/rtc:
total 0
drwxr-xr-x 3 root root 0 Mar 27 15:32 .
drwxr-xr-x 4 root root 0 Mar 27 15:32 ..
drwxr-xr-x 3 root root 0 Mar 27 14:09 rtc0
Mon Mar 27, 2017 3:04 pm
What did you add to /boot/config.txt for your RTC?
Anything more in /sys/bus/i2c/drivers/rtc-ds1307/*
gregeric
Mon Mar 27, 2017 3:09 pm
DS3231 temperature sensor readout is in kernels >=4.6 AFAICR
darkbibble
Mon Mar 27, 2017 3:19 pm
 # turn real time clock on
dtoverlay=i2c-rtc,ds3231
gpu_mem_256=128
gpu_mem_512=256
gpu_mem_1024=256
overscan_scale=1
dtparam=i2c1=on
dtparam=i2c1_baudrate=50000
pi@pi-top:/sys/bus/i2c/drivers/rtc-ds1307 $ ls
1-0068 bind module uevent unbind
Mon Mar 27, 2017 3:22 pm
OK, so it looks like the kernel driver in the RPF kernel doesn't support reading the temperature registers from your ds3231.
Sorry, I can't fix it for sure. I don't have a ds3231 handy. Try sudo rpi-update to get the 4.9 kernel.
gregeric
Mon Mar 27, 2017 3:46 pm
Or, cherry pick the newer rtc-ds1307.c source and build & replace rtc-ds1307.ko. That's what i did. Let me know if you need a quick run down on that.
Mon Mar 27, 2017 3:52 pm
gregeric wrote:Or, cherry pick the newer rtc-ds1307.c source and build & replace rtc-ds1307.ko. That's what i did. Let me know if you need a quick run down on that.
rpi-update to 4.9.17 is probably safer for a general user in this case, building kernels isn't for the faint hearted. I know we don't usually recommend rpi-update but this is one case where jumping from 4.4.50 to 4.9.17 may solve the OP's problems.
Twelve out of fourteen of my raspberries are running 4.9.17 so we can assume it's relatively safe and won't turn the OP's RPi into a brain-dead corpse that won't boot.
gregeric
Mon Mar 27, 2017 4:06 pm
Build the module alone, not the entire kernel. I have a simple recipe for that, will post it later.
gregeric
Mon Mar 27, 2017 6:14 pm
So, to build only the required rtc-ds1307.ko to get DS3231 temperature support in kernels <4.6.
Firstly, get kernel header files:
sudo apt-get update && sudo apt-get dist-upgrade
sudo apt-get install -y raspberrypi-kernel-headers
sudo reboot
After reboot,
mkdir ds1307
cd ds1307
wget https://raw.githubusercontent.com/raspberrypi/linux/rpi-4.9.y/drivers/rtc/rtc-ds1307.c
nano Makefile
Makefile contents (indent is a single <tab>, not spaces):
obj-m := rtc-ds1307.o
ccflags-y += -DCONFIG_RTC_DRV_DS1307_HWMON
all:
	make -C /lib/modules/$(shell uname -r)/build M=$(PWD) modules
clean:
	make -C /lib/modules/$(shell uname -r)/build M=$(PWD) clean
install:
	sudo cp rtc-ds1307.ko /lib/modules/$(shell uname -r)/kernel/drivers/rtc/
	sudo depmod -a
Backup old module, build & install:
sudo cp /lib/modules/$(uname -r)/kernel/drivers/rtc/rtc-ds1307.ko /lib/modules/$(uname -r)/kernel/drivers/rtc/rtc-ds1307.ko.bak
make clean all install
sudo reboot
Test the sensor:
sudo apt-get install -y lm-sensors
sensors
Output should be something like this:
ds3231-i2c-1-68
Adapter: 20804000.i2c
temp1:        +20.8°C
darkbibble
Tue Mar 28, 2017 6:17 pm
thanks, i did "sudo rpi-update" to update kernal, then installed the sensor module,
works great
