JayinHouston
Power cord upgrade
Mon Mar 27, 2017 5:53 am
I keep getting a lightning bolt icon appear in the corner of my screen. Is it possible to use a higher voltage power supply to provide power to the Pi3?
Raspberry Pi 3B running Raspian Jessie. Smarticase with Raspberry Pi Official 7" Touchscreen.
Houston, TX USA
ghans
Re: Power cord upgrade
Mon Mar 27, 2017 6:05 am
You need more amps instead of more volts , you should also check the cord itself for its length (shorter =better).
ghans
JayinHouston
Mon Mar 27, 2017 7:12 am
ghans wrote:You need more amps instead of more volts , you should also check the cord itself for its length (shorter =better).
ghans
Thank you. What would be the safest max amps we could go?
Houston, TX USA
RaTTuS
Contact: Twitter YouTube
Mon Mar 27, 2017 7:20 am
a good quality 2.4A 5V PSU and a good quality micro usb lead [shorter ] will be all you need
what are you using now?
Covfefe
ghans
Mon Mar 27, 2017 9:33 am
You could use a 10 or 100 Ampere supply , it doesn't matter because those are maximum ratings.
What matters is that the supply stays over 4.75 and under 5.2 Volt when under load.
ghans
JayinHouston
Mon Mar 27, 2017 4:22 pm
RaTTuS wrote:a good quality 2.4A 5V PSU and a good quality micro usb lead [shorter ] will be all you need
5V 2.5 amp
Houston, TX USA
MarkyV
Mon Mar 27, 2017 10:57 pm
Do you have anything else plugged into the Pi - USB peripherals, HATs, servos or cameras? - they can draw extra amps - a 2.5Amp 5V PSU should not cause this problem on a bare Pi3B - if it is just the Pi3B, screen and keyboard/mouse then you may have a faulty PSU.
Mark
My RaspberryPi Blog: http://thepimaker.online
W. H. Heydt
Tue Mar 28, 2017 5:33 am
Technically...you do need a higher voltage. The lightning bolt indicates that the "5v" plane is at 4.63v or less. However, going for a higher voltage PSU is NOT the answer. There are a number problems that can result in an undervoltage condition.
The PSU may not maintain proper voltage under load, especially load near its current rating. Answer: Get a PSU with a higher current rating so you're not runing it near its limit, or get a better PSU, one that can deliver its full rated current without having the voltage drop.
The cable from the PSU to the Pi may not be able to carry the full current without the internal resistance dragging the voltage down. Answer: Get a shorter and/or thicker power cable.
Too much current draw from connected devices. The Pi has current limiting protections. A Pi3B can not draw more than 2.4A. Of that, 1.2A is available for attached USB devices. Answer: Use a powered hub for at least some USB devices.
