yavstr
NXP Pressure Sensor, Vacuum
Fri Mar 24, 2017 4:52 pm
Please excuse my ignorance if this has been asked, I spent 30 minutes searching and weeding through posts before posting.
I recently started working with the Pi and have hooked up a few temperature/humidity sensors with Adafruit_DHT and am now trying to hookup a Pressure Sensor but having no luck finding an example of Python code and to be quite honest I'm not sure how to wire the sensor to the pi.
This is the sensor that I have:
http://www.newark.com/freescale-semicon ... dp/75C3920
I've been told this should work with the Pi but heck if I can figure that out or find an example. I've exhausted a few days scouring the web before asking here.
Thank you in advance for any help you can give or direction as it will be greatly appreciated.
gordon@drogon.net
Re: NXP Pressure Sensor, Vacuum
Fri Mar 24, 2017 5:17 pm
yavstr wrote:Please excuse my ignorance if this has been asked, I spent 30 minutes searching and weeding through posts before posting.
I've been told this should work with the Pi but heck if I can figure that out or find an example. I've exhausted a few days showering the web before asking here.
It's an analog output device. So to make it work on the Pi you'll need an ADC between it and the Pi.
-Gordon
Gordons projects: https://projects.drogon.net/
yavstr
Fri Mar 24, 2017 6:23 pm
-Gordon
Thanks for your response Gordon, do you have any suggestions on a good ADC that would work?
Manivannan553
Thu Jan 09, 2020 12:09 pm
MPC3008 or ADS1115 or ADS1015...
