Raspbian 2017-03-02 Causes Blank Screen
Posted: Tue Mar 14, 2017 2:30 am
by epretorious
Hello, All:
My Raspberry Pi 3, Model B is connected to my Dell 2007FP (1600x1200 @ 60 Hz) with an HDMI-DVI adapter. When I was using NOOBS, video was working using these settings (in /boot/config.txt):
hdmi_group=2
hdmi_mode=51
hdmi_drive=1
Now that I've switched to Rasbian, Version 2017-03-02, video has stopped working entirely.
What happened?
Eric Pretorious
Portland, Oregon
Re: Raspbian 2017-03-02 Causes Blank Screen
Posted: Wed Mar 15, 2017 2:42 am
by epretorious
I reverted to NOOBS, Version 2017-03-02; rebooted twice; used NOOBS to install Raspbian Jessie; manually edited /boot/config.txt [to restore the values that had worked for me previously] and the R-Pi is able to use the Dell 2007FP again at 1600x1200 resolution [with the HDMI cable and HDMI-DVI adapter] but the image is blurry. :shock:
The modifications that I've made to /boot/config.txt:
framebuffer_width=1600
framebuffer_height=1200
hdmi_group=2
hdmi_mode=51
hdmi_drive=1
(These are the settings that worked previously.)
What's causing this? What can I do to make the image clear?
Eric Pretorious
Portland, OR
