Thlorian
Line command not working
Wed Mar 08, 2017 8:08 pm
OK so I got a rasp pi up and running FINALLY and I am going thru beginner commands, etc.. Every time I enter the ls -1 command to see details of a folder, it's as if the command ignores me and still just shows just the name of the folder with no detaiks....even if I am in sudo mode... gotta be user error but I can't figure it out???
emgi
Re: Line command not working
Wed Mar 08, 2017 8:11 pm
Give it a try with the letter that looks almost the same...
Otherwise, try
man ls
/emgi
klricks
Wed Mar 08, 2017 8:12 pm
It is ls -l (ell) not ls-1(one)
gordon77
Do you need ls -l not ls -1?
Thlorian
Thu Mar 09, 2017 2:49 am
Well don't I feel sheepish! Thanks folks as user error on this one ... I was using the number 1 ... :mrgreen:
tech-mech
Contact: Yahoo Messenger
Thu Mar 09, 2017 7:23 am
This is the fun of the command line. Some fonts are worse than others. Is it a1 or an l, is it a 0, O, or o.
On longer command line strings from web sites it can be very hard to get it right. It would help if people who post the commands with confusing letters that are similar to numbers would add a note as to what is intended.
Dale
PeterO
Thu Mar 09, 2017 7:32 am
A Tip : Cut and Paste the command text into a console window, or an editor , or something else where you can select the font and size. Sadly this doesn't help with printed materials which can be some of the worst offenders for using inappropriate fonts!
PeterO
