Usb port advice.
Posted: Sat Mar 04, 2017 8:01 pm
by huddling
So, the project I am working on has already claimed the life of one raspberry pi 3 model b+ when I stupidly attempted to remove one of the dual usb towers. The reason I wanted to do that was because I am soldering a wired xbox 360 controller directly to the board and that would mean the ports would be taking up valuable space up in the case. I dont want to risk breaking another pi so any suggestions as to other ways I could solder the controller to the pi or remove just the top usb port would be great.
Re: Usb port advice.
Posted: Sat Mar 04, 2017 8:48 pm
by alphanumeric
You could just solder the wires to the pads (circuit board) under the port without removing it. Just tape over it so nothing else gets plugged into it. You'll only have issues if two devices are connected to the same port. You don't have to remove it, unless you have clearance issues.
Posted: Sat Mar 04, 2017 9:15 pm
by huddling
alphanumeric wrote:You could just solder the wires to the pads (circuit board) under the port without removing it. Just tape over it so nothing else gets plugged into it. You'll only have issues if two devices are connected to the same port. You don't have to remove it, unless you have clearance issues.
I like this idea, but I feel like tape would look ugly and would fall off over time. I'm looking for a more permanent solutio.
Posted: Sat Mar 04, 2017 9:26 pm
by alphanumeric
Fill that one port with hot glue?
Posted: Sat Mar 04, 2017 9:33 pm
by huddling
alphanumeric wrote:Fill that one port with hot glue?
I will take this as my last resort if nobody suggests a better idea. Thanks ;)
Posted: Sat Mar 04, 2017 9:34 pm
by Ernst
http://www.lindy-usa.com/usb-port-block ... 40464.html
Posted: Sat Mar 04, 2017 9:41 pm
by huddling
Literally the perfect solution. Thank you so much!
Posted: Sat Mar 04, 2017 10:34 pm
by huddling
Whilst I have a thread already open about USB ports, I might as well ask another question.
On the 2-high usb slots, which slot corresponds to which points?
Posted: Sun Mar 05, 2017 10:30 am
by alphanumeric
If you have an ohm meter trace one of the DATA pins. I think you'll find the ones closest to the edge of the board go to the bottom one. And the second set back go to the top one.
Posted: Sun Mar 05, 2017 1:25 pm
by huddling
alphanumeric wrote:If you have an ohm meter trace one of the DATA pins. I think you'll find the ones closest to the edge of the board go to the bottom one. And the second set back go to the top one.
Awesome! thanks.
