RDS
config.txt file
Fri Mar 03, 2017 9:51 am
I need to change a setting in the config.txt file within /boot but I get the following error message
Can't open file to write
I have have overcome this in the past by copying the file using the Terminal window.
That seemed a very long way round.
Is there an easier way of getting permission?
hansotten
Re: config.txt file
Fri Mar 03, 2017 9:58 am
You have no permsission as user pi to write to system files, for obvious reasons, to prevent accidental damage to the system.
To get access you can elevate your level so admin level with the sudo command temporarely
sudo nano /boot/config.txt
http://duinorasp.hansotten.com for Raspberry Pi and Arduino and ESP8266
http://retro.hansotten.nl for retrocomputing with the 6502 cpu
runboy93
Re: config.txt file
Fri Mar 03, 2017 10:00 am
Most important thing on linux world, sudo! Remember it always.
Re: config.txt file
Fri Mar 03, 2017 12:07 pm
runboy93 wrote:Most important thing on linux world, sudo! Remember it always.
Use it sparingly.
Too many folks find sudo and run everything with root privileges. When you've run sudo rm -rf / just once you soon learn why sudo should be used sparingly.
This is a doctor free zone.
fred44nl
Re: config.txt file
Fri Mar 03, 2017 12:21 pm
DougieLawson wrote:When you've run sudo rm -rf / just once you soon learn why sudo should be used sparingly.
sounds like "Format C: " :shock:
headless RPi 3B running from usbhdd.
mahjongg
Re: config.txt file
Fri Mar 03, 2017 12:24 pm
Yeah, it means remove recursively. It deletes every file on your system.
RDS
Re: config.txt file
Fri Mar 03, 2017 2:05 pm
@hansotten
Thank you
and thanks to all for the warnings.
(I just wanted to change the set up so that it always starts in HDMI mode. I have done this on all my Pi's (4 off total to make headless running better)
W. H. Heydt
Re: config.txt file
Fri Mar 03, 2017 2:47 pm
On a clear disk, you can seek forever.
TracyLBaker
Re: config.txt file
Fri Mar 03, 2017 8:51 pm
rm -rf / means remove recursively (the r part) and forcefully (the f part) -- it all means remove all directories, beginning at the root of the file system (the / part) and don't ask "are you sure?"
The / refers to the root of the file system -- sorta like C: in Windows.
Red Hat Academy Professor - Estrella Mountain Community College
5 Pi 3 Model B+s: 1 headless media/NFS/SMB server - Raspbian Jessie, 1 Kali Linux w/fruitywifi, 1 headless CentOS 7 webserver (Apache, SELinux, firewalld, autofs, etc...), 2 in waiting
