ctrygstad
Making WiFi available when configured as hotspot
Wed Mar 01, 2017 5:37 pm
I have a Raspberry Pi configured as a WiFi hotspot, and it runs ExpressJS as a web server for a number of JS services, including Angular and Socket.io, etc. To operate the web server application, I plan on using a mobile client such as a tablet or laptop to connect to the Raspberry Pi via WiFi and then access the web app on the web server.
One issue I'm running into is the speed at which the WiFi network is available to my mobile client. It usually takes over 1 minute before the WiFi network is available to connect to. Is there a way to customize the boot sequence to turn off unneeded services or another alternative to make the WiFi network served by the Raspberry Pi available earlier after reboot or bootup?
I have copy from the boot log by using the dmesg|less command, the code is below.
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.1.18-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3 (crosstool-NG crosstool-ng-1.22.0-88-g8460611) ) #846 SMP Thu Feb 25 14:22:53 GMT 2016
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[    0.000000] cma: Reserved 8 MiB at 0x3a400000
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] On node 0 totalpages: 241664
[    0.000000] free_area_init_node: node 0, pgdat 80876f80, node_mem_map b9bb4000
[    0.000000]   Normal zone: 2124 pages used for memmap
[    0.000000]   Normal zone: 0 pages reserved
[    0.000000]   Normal zone: 241664 pages, LIFO batch:31
[    0.000000] [bcm2709_smp_init_cpus] enter (9420->f3003010)
[    0.000000] [bcm2709_smp_init_cpus] ncores=4
[    0.000000] PERCPU: Embedded 12 pages/cpu @bafb0000 s20416 r8192 d20544 u49152
[    0.000000] pcpu-alloc: s20416 r8192 d20544 u49152 alloc=12*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 239540
[    0.000000] Kernel command line: 8250.nr_uarts=1 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2709.boardrev=0xa22082 bcm2709.serial=0x1431914 smsc95xx.macaddr=B8:27:EB:43:19:14 bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 939416K/966656K available (6024K kernel code, 534K rwdata, 1660K rodata, 448K init, 757K bss, 19048K reserved, 8192K cma-reserved)
[    0.000000] Virtual kernel memory layout:
    vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    vmalloc : 0xbb800000 - 0xff000000   (1080 MB)
    lowmem  : 0x80000000 - 0xbb000000   ( 944 MB)
    modules : 0x7f000000 - 0x80000000   (  16 MB)
      .text : 0x80008000 - 0x807895a0   (7686 kB)
      .init : 0x8078a000 - 0x807fa000   ( 448 kB)
      .data : 0x807fa000 - 0x8087fac0   ( 535 kB)
       .bss : 0x80882000 - 0x8093f79c   ( 758 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Additional per-CPU info printed with stalls.
[    0.000000] NR_IRQS:608
[    0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000025] Switching to timer-based delay loop, resolution 52ns
[    0.000238] Console: colour dummy device 80x30
[    0.001282] console [tty1] enabled
[    0.001335] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.001404] pid_max: default: 32768 minimum: 301
[    0.001722] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001766] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.002756] Initializing cgroup subsys blkio
[    0.002804] Initializing cgroup subsys memory
[    0.002851] Initializing cgroup subsys devices
[    0.002895] Initializing cgroup subsys freezer
[    0.002945] Initializing cgroup subsys net_cls
[    0.003014] CPU: Testing write buffer coherency: ok
[    0.003102] ftrace: allocating 20309 entries in 60 pages
[    0.048623] CPU0: update cpu_capacity 1024
[    0.048686] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.048718] [bcm2709_smp_prepare_cpus] enter
[    0.048867] Setting up static identity map for 0x8240 - 0x8274
[    0.050596] [bcm2709_boot_secondary] cpu:1 started (0) 18
[    0.050944] [bcm2709_secondary_init] enter cpu:1
[    0.050987] CPU1: update cpu_capacity 1024
[    0.050994] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.051364] [bcm2709_boot_secondary] cpu:2 started (0) 17
[    0.051620] [bcm2709_secondary_init] enter cpu:2
[    0.051642] CPU2: update cpu_capacity 1024
[    0.051648] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.052006] [bcm2709_boot_secondary] cpu:3 started (0) 17
[    0.052190] [bcm2709_secondary_init] enter cpu:3
[    0.052211] CPU3: update cpu_capacity 1024
[    0.052217] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.052279] Brought up 4 CPUs
[    0.052377] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.052407] CPU: All CPU(s) started in HYP mode.
[    0.052433] CPU: Virtualization extensions available.
[    0.053126] devtmpfs: initialized
[    0.071384] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.071650] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.072510] pinctrl core: initialized pinctrl subsystem
[    0.073057] NET: Registered protocol family 16
[    0.078177] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[    0.079145] bcm2709.uart_clock = 48000000
[    0.083104] bcm2709: Mini UART enabled
[    0.083615] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.083662] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.083834] Serial: AMBA PL011 UART driver
[    0.083985] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev2
[    0.084422] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.149363] bcm2708-dmaengine 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0xf35
[    0.149434] bcm2708-dmaengine 3f007000.dma: Initialized 7 DMA channels (+ 1 legacy)
[    0.150026] bcm2708-dmaengine 3f007000.dma: Load BCM2835 DMA engine driver
[    0.150063] bcm2708-dmaengine 3f007000.dma: dma_debug:0
[    0.150642] SCSI subsystem initialized
[    0.150839] usbcore: registered new interface driver usbfs
[    0.150945] usbcore: registered new interface driver hub
[    0.151067] usbcore: registered new device driver usb
[    0.151608] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-02-25 14:25
[    0.178694] Switched to clocksource arch_sys_counter
[    0.220231] FS-Cache: Loaded
[    0.220516] CacheFiles: Loaded
[    0.229719] NET: Registered protocol family 2
[    0.230680] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.230822] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.231032] TCP: Hash tables configured (established 8192 bind 8192)
[    0.231146] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.231215] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.231545] NET: Registered protocol family 1
[    0.231865] RPC: Registered named UNIX socket transport module.
[    0.231898] RPC: Registered udp transport module.
[    0.231926] RPC: Registered tcp transport module.
[    0.231953] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.232893] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    0.233995] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.247386] VFS: Disk quotas dquot_6.6.0
[    0.247721] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.249797] FS-Cache: Netfs 'nfs' registered for caching
[    0.250727] NFS: Registering the id_resolver key type
[    0.250804] Key type id_resolver registered
[    0.250833] Key type id_legacy registered
[    0.252898] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[    0.253073] io scheduler noop registered
[    0.253113] io scheduler deadline registered (default)
[    0.253404] io scheduler cfq registered
[    0.255663] BCM2708FB: allocated DMA memory fa800000
[    0.255710] BCM2708FB: allocated DMA channel 0 @ f3007000
[    0.260690] Console: switching to colour frame buffer device 82x26
[    0.265040] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
[    0.270151] console [ttyS0] disabled
[    0.271614] 3f215040.uart: ttyS0 at MMIO 0x3f215040 (irq = 29, base_baud = 50000000) is a 16550
[    1.467946] console [ttyS0] enabled
[    1.475921] vc-cma: Videocore CMA driver
[    1.483685] vc-cma: vc_cma_base      = 0x00000000
[    1.492677] vc-cma: vc_cma_size      = 0x00000000 (0 MiB)
[    1.502754] vc-cma: vc_cma_initial   = 0x00000000 (0 MiB)
[    1.512920] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[    1.540089] brd: module loaded
[    1.553209] loop: module loaded
[    1.560376] vchiq: vchiq_init_state: slot_zero = 0xba880000, is_master = 0
[    1.574306] Loading iSCSI transport class v2.0-870.
[    1.584185] usbcore: registered new interface driver smsc95xx
[    1.594893] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.805868] Core Release: 2.80a
[    1.812303] Setting default values for core params
[    1.821465] Finished setting default values for core params
[    2.032216] Using Buffer DMA mode
[    2.038931] Periodic Transfer Interrupt Enhancement - disabled
[    2.049758] Multiprocessor Interrupt Enhancement - disabled
[    2.060139] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.068514] Dedicated Tx FIFOs mode
[    2.075743] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xba814000 dma = 0xfa814000 len=9024
[    2.094437] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[    2.127072] dwc_otg: Microframe scheduler enabled
[    2.127122] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x8040ecc0
[    2.138107] WARN::hcd_init_fiq:413: FIQ ASM at 0x8040f030 length 36
[    2.149681] WARN::hcd_init_fiq:438: MPHI regs_base at 0xbb89c000
[    2.160825] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.170257] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.183520] dwc_otg 3f980000.usb: irq 32, io mem 0x00000000
[    2.193954] Init: Port Power? op_state=1
[    2.201652] Init: Power Port (0)
[    2.208369] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    2.220758] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.233835] usb usb1: Product: DWC OTG Controller
[    2.242796] usb usb1: Manufacturer: Linux 4.1.18-v7+ dwc_otg_hcd
[    2.253882] usb usb1: SerialNumber: 3f980000.usb
[    2.263331] hub 1-0:1.0: USB hub found
[    2.270757] hub 1-0:1.0: 1 port detected
[    2.278741] dwc_otg: FIQ enabled
[    2.278750] dwc_otg: NAK holdoff enabled
[    2.278758] dwc_otg: FIQ split-transaction FSM enabled
[    2.278790] Module dwc_common_port init
[    2.279044] usbcore: registered new interface driver usb-storage
[    2.290216] mousedev: PS/2 mouse device common for all mice
[    2.301153] bcm2835-cpufreq: min=600000 max=1200000
[    2.310646] sdhci: Secure Digital Host Controller Interface driver
[    2.321997] sdhci: Copyright(c) Pierre Ossman
[    2.330656] sdhost: log_buf @ ba813000 (fa813000)
[    2.418726] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    2.451310] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[    2.462135] mmc-bcm2835 3f300000.mmc: DMA channels allocated
[    2.468791] Indeed it is in host mode hprt0 = 00021501
[    2.518813] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.529674] ledtrig-cpu: registered to indicate activity on CPUs
[    2.540863] hidraw: raw HID events driver (C) Jiri Kosina
[    2.543644] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.547346] mmc0: new high speed SDHC card at address aaaa
[    2.547781] mmcblk0: mmc0:aaaa SL32G 29.7 GiB
[    2.550216]  mmcblk0: p1 p2
[    2.568163] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    2.569726] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.571285] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    2.574100] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    2.632519] usbcore: registered new interface driver usbhid
[    2.642832] usbhid: USB HID core driver
[    2.650719] Initializing XFRM netlink socket
[    2.658896] NET: Registered protocol family 17
[    2.665156] mmc1: new high speed SDIO card at address 0001
[    2.668722] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    2.668840] Indeed it is in host mode hprt0 = 00001101
[    2.698862] Key type dns_resolver registered
[    2.707462] Registering SWP/SWPB emulation handler
[    2.717148] registered taskstats version 1
[    2.725241] vc-sm: Videocore shared memory driver
[    2.734120] [vc_sm_connected_init]: start
[    2.742300] [vc_sm_connected_init]: end - returning 0
[    2.757296] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    2.770377] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    2.858982] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[    2.871085] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.884559] hub 1-1:1.0: USB hub found
[    2.891960] hub 1-1:1.0: 5 ports detected
[    3.178730] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.288983] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[    3.301513] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.317453] smsc95xx v1.0.4
[    3.381927] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:43:19:14
[    3.478737] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[    3.513405] EXT4-fs (mmcblk0p2): orphan cleanup on readonly fs
[    3.524645] EXT4-fs (mmcblk0p2): 1 orphan inode deleted
[    3.534561] EXT4-fs (mmcblk0p2): recovery complete
[    3.557113] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.573182] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.589243] devtmpfs: mounted
[    3.596352] Freeing unused kernel memory: 448K (8078a000 - 807fa000)
[    3.609516] usb 1-1.4: New USB device found, idVendor=0a5c, idProduct=bd1e
[    3.622278] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    3.635716] usb 1-1.4: Product: Remote Download Wireless Adapter
[    3.647034] usb 1-1.4: Manufacturer: Broadcom
[    3.655641] usb 1-1.4: SerialNumber: 000000000001
[    3.972271] random: systemd urandom read with 80 bits of entropy available
[    3.991046] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[    4.016259] systemd[1]: Detected architecture 'arm'.
[    4.193080] NET: Registered protocol family 10
[    4.203131] systemd[1]: Inserted module 'ipv6'
[    4.217592] systemd[1]: Set hostname to <raspberrypi>.
[    4.844017] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[    4.859797] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    4.875146] systemd[1]: Expecting device dev-ttyS0.device...
[    4.887822] systemd[1]: Starting Remote File Systems (Pre).
[    4.900289] systemd[1]: Reached target Remote File Systems (Pre).
[    4.911952] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[    4.931577] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    4.950119] systemd[1]: Starting Encrypted Volumes.
[    4.961628] systemd[1]: Reached target Encrypted Volumes.
[    4.972122] systemd[1]: Starting Swap.
[    4.981788] systemd[1]: Reached target Swap.
[    4.990464] systemd[1]: Expecting device dev-mmcblk0p1.device...
[    5.003784] systemd[1]: Starting Root Slice.
[    5.014198] systemd[1]: Created slice Root Slice.
[    5.023426] systemd[1]: Starting User and Session Slice.
[    5.035537] systemd[1]: Created slice User and Session Slice.
[    5.046449] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[    5.060678] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[    5.073581] systemd[1]: Starting Delayed Shutdown Socket.
[    5.085678] systemd[1]: Listening on Delayed Shutdown Socket.
[    5.096508] systemd[1]: Starting Journal Socket (/dev/log).
[    5.108848] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.119991] systemd[1]: Starting udev Control Socket.
[    5.131476] systemd[1]: Listening on udev Control Socket.
[    5.141791] systemd[1]: Starting udev Kernel Socket.
[    5.153121] systemd[1]: Listening on udev Kernel Socket.
[    5.163311] systemd[1]: Starting Journal Socket.
[    5.174142] systemd[1]: Listening on Journal Socket.
[    5.183818] systemd[1]: Starting System Slice.
[    5.194364] systemd[1]: Created slice System Slice.
[    5.203824] systemd[1]: Starting File System Check on Root Device...
[    5.219524] systemd[1]: Starting system-systemd\x2dfsck.slice.
[    5.232914] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    5.244837] systemd[1]: Starting system-autologin.slice.
[    5.257213] systemd[1]: Created slice system-autologin.slice.
[    5.268131] systemd[1]: Starting system-serial\x2dgetty.slice.
[    5.281339] systemd[1]: Created slice system-serial\x2dgetty.slice.
[    5.293171] systemd[1]: Starting Increase datagram queue length...
[    5.308658] systemd[1]: Starting Restore / save the current clock...
[    5.327286] systemd[1]: Mounting POSIX Message Queue File System...
[    5.343358] systemd[1]: Mounted Huge Pages File System.
[    5.354096] systemd[1]: Mounting Debug File System...
[    5.391675] systemd[1]: Started Set Up Additional Binary Formats.
[    5.420215] systemd[1]: Starting Load Kernel Modules...
[    5.434853] systemd[1]: Starting udev Coldplug all Devices...
[    5.451165] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[    5.474625] systemd[1]: Starting Slices.
[    5.485594] systemd[1]: Reached target Slices.
[    5.500666] systemd[1]: Mounted Debug File System.
[    5.513054] systemd[1]: Mounted POSIX Message Queue File System.
[    5.527954] systemd[1]: Started Increase datagram queue length.
[    5.574914] fuse init (API version 7.23)
[    5.586173] systemd[1]: Started Restore / save the current clock.
[    5.604604] systemd[1]: Started Create list of required static device nodes for the current kernel.
[    5.638187] systemd[1]: Started File System Check on Root Device.
[    5.653757] systemd[1]: Started udev Coldplug all Devices.
[    5.667106] systemd[1]: Time has been changed
[    5.697094] i2c /dev entries driver
[    5.713708] systemd[1]: Started Load Kernel Modules.
[    5.826447] systemd[1]: Starting Apply Kernel Variables...
[    5.841833] systemd[1]: Mounting Configuration File System...
[    5.857472] systemd[1]: Mounting FUSE Control File System...
[    5.873738] systemd[1]: Starting Create Static Device Nodes in /dev...
[    5.878862] systemd[1]: Starting Syslog Socket.
[    5.881467] systemd[1]: Listening on Syslog Socket.
[    5.881638] systemd[1]: Starting Journal Service...
[    5.888815] systemd[1]: Started Journal Service.
[    6.062293] systemd-udevd[110]: starting version 215
[    6.745469] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.799468] cfg80211: Calling CRDA to update world regulatory domain
[    6.950662] brcmfmac: brcmf_sdio_drivestrengthinit: No SDIO Drive strength init done for chip 43430 rev 1 pmurev 24
[    6.954071] usbcore: registered new interface driver brcmfmac
[    7.114186] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[    7.115407] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    7.141368] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Dec 15 2015 18:10:45 version 7.45.41.23 (r606571) FWID 01-cc4eda9c
[    7.177244] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    7.207792] random: nonblocking pool is initialized
[    7.331578] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Apr  3 2014 04:43:32 version 6.10.198.66 (r467479) FWID 01-32bd010e
[    7.354670] brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
[    7.456925] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[    7.456960] brcmfmac: brcmf_add_if: ignore IF event
[    7.520300] brcmfmac: brcmf_add_if: ERROR: netdev:wlan1 already exists
[    7.520341] brcmfmac: brcmf_add_if: ignore IF event
[    7.590133] bcm2835-rng 3f104000.rng: hwrng registered
[    7.596759] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    7.672513] systemd-journald[108]: Received request to flush runtime journal from PID 1
[    9.948753] cfg80211: Calling CRDA to update world regulatory domain
[   13.098739] cfg80211: Calling CRDA to update world regulatory domain
[   16.248754] cfg80211: Calling CRDA to update world regulatory domain
[   19.398718] cfg80211: Calling CRDA to update world regulatory domain
[   22.548764] cfg80211: Calling CRDA to update world regulatory domain
[   25.698740] cfg80211: Calling CRDA to update world regulatory domain
[   27.596751] Adding 102396k swap on /var/swap.  Priority:-1 extents:5 across:573436k SSFS
[   28.121803] ip_tables: (C) 2000-2006 Netfilter Core Team
[   28.183834] nf_conntrack version 0.5.0 (14813 buckets, 59252 max)
[   28.257875] brcmfmac: brcmf_add_if: ERROR: netdev:wlan0 already exists
[   28.257889] brcmfmac: brcmf_add_if: ignore IF event
[   28.848752] cfg80211: Calling CRDA to update world regulatory domain
[   31.998812] cfg80211: Calling CRDA to update world regulatory domain
[   35.158793] cfg80211: Calling CRDA to update world regulatory domain
[   38.308818] cfg80211: Calling CRDA to update world regulatory domain
[   41.458784] cfg80211: Exceeded CRDA call max attempts. Not calling CRDA
Return to “Beginners”
