Can't update or upgrade
Posted: Tue Feb 28, 2017 8:52 pm
by Neddie
Hi all.
I have been trying to install a package (VLC) but I keep getting errors. Can't install Motion either.
Then I tried apt-get upgrade , that failed , can't find all sorts of stuff.
I then re-installed Jessie (downloaded on 11/1/2017) which I have used 5 or 6 times without any issues.
Sudo apt-get update or upgrade still wont work. Are there some servers down or something. I can't install anything at all.
Trying to install VLC I get these errors , but I get the same if I do a sudo apt-get upgrade.
Sorry about the formatting I copied it from the terminal window. It goes on for pages and pages , I'm just showing a few lines.
BTW I can browse the internet using Cromium , so my pi does have an internet connection. ping also works :0)
pi@raspberrypi:~ $ sudo apt-get install vlc
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
liba52-0.7.4 libbasicusageenvironment0 libcddb2 libdvbpsi9 libebml4
libfreerdp-cache1.1 libfreerdp-client1.1 libfreerdp-codec1.1
libfreerdp-common1.1.0 libfreerdp-core1.1 libfreerdp-crypto1.1
libfreerdp-gdi1.1 libfreerdp-locale1.1 libfreerdp-primitives1.1
libfreerdp-rail1.1 libfreerdp-utils1.1 libgroupsock1 libiso9660-8
liblircclient0 liblivemedia23 liblua5.2-0 libmatroska6 libmpcdec6 libmpeg2-4
libpostproc52 libproxy-tools libresid-builder0c2a libshine3 libsidplay2
libtwolame0 libupnp6 libusageenvironment1 libva-drm1 libva-x11-1 libva1
libvcdinfo0 libvlc5 libvlccore8 libvncclient0 libwinpr-crt0.1
libwinpr-crypto0.1 libwinpr-dsparse0.1 libwinpr-environment0.1
libwinpr-file0.1 libwinpr-handle0.1 libwinpr-heap0.1 libwinpr-input0.1
libwinpr-interlocked0.1 libwinpr-library0.1 libwinpr-path0.1
libwinpr-pool0.1 libwinpr-registry0.1 libwinpr-rpc0.1 libwinpr-sspi0.1
libwinpr-synch0.1 libwinpr-sysinfo0.1 libwinpr-thread0.1 libwinpr-utils0.1
libxcb-composite0 libxcb-keysyms1 libxcb-randr0 libxcb-xv0 libzvbi-common
libzvbi0 vlc-data vlc-nox vlc-plugin-notify vlc-plugin-samba
Suggested packages:
freerdp-x11 lirc videolan-doc libdvdcss2
libtwolame0 libupnp6 libusageenvironment1 libva-drm1 libva-x11-1 libvcdinfo0
libvlc5 libvlccore8 libvncclient0 libwinpr-crt0.1 libwinpr-crypto0.1
libwinpr-dsparse0.1 libwinpr-environment0.1 libwinpr-file0.1
libzvbi0 vlc vlc-data vlc-nox vlc-plugin-notify vlc-plugin-samba
The following packages will be upgraded:
libva1
1 upgraded, 68 newly installed, 0 to remove and 150 not upgraded.
Need to get 16.8 MB/16.9 MB of archives.
After this operation, 64.1 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libbasicusageenvironment0 armhf 2014.01.13-1
Cannot initiate the connection to mirror.liquidtelecom.com:80 (2c0f:fe40:8001:10::1). - connect (101: Network is unreachable) [IP: 2c0f:fe40:8001:10::1 80]
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libdvbpsi9 armhf 1.2.0-1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libebml4 armhf 1.3.0-2+deb8u1
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-sysinfo0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libfreerdp-primitives1.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-crt0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-environment0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Err http://mirrordirector.raspbian.org/raspbian/ jessie/main libwinpr-handle0.1 armhf 1.1.0~git20140921.1.440916e+dfsg1-4
Any ideas please.
Cheers
Neddie
Re: Can't update or upgrade
Posted: Wed Mar 01, 2017 12:41 am
by eyesofnova
I did a fresh install last night on both my pi zero and my pi 3 and while my pi zero can update/upgrade with no problem my pi 3 is having the same issue as you.
Posted: Wed Mar 01, 2017 6:27 am
by Neddie
My PI2 is also giving the same error :0(
Not sure where to go from here. If it was /is a general Linux upgrade issue
I'd have expected to see a lot more noise on the issue , but nothing out of
the ordinary.
I'm going to try it at work today and see if I get the same results.
Neddie
Posted: Wed Mar 01, 2017 6:39 am
by plugwash
We recently split services up among more servers due to ever-increasing demand.
It looks like we are having issues with database replication from the machine that scans the mirrors to the machine that runs the public mirror redirection service.
Posted: Wed Mar 01, 2017 6:51 am
by plugwash
I have changed the replication settings and done a forced update of the db. The liquidtelecom mirror is now correctly showing as offline.
Please tell me if you have any further problems.
Posted: Wed Mar 01, 2017 7:40 am
by Neddie
Phew , thought I was going nuts. I'm sure that is what the problem was , I'll
come back if the issue is NOT fixed.
Cheers
Neddie
Posted: Wed Mar 01, 2017 8:14 am
by fruitoftheloom
Neddie wrote:Phew , thought I was going nuts. I'm sure that is what the problem was , I'll
Cheers
Neddie
You are not going nuts, it would appear that more servers are hosting worldwide, and for some reason they are not synching. It happened to me yesterday.
Posted: Fri Mar 03, 2017 3:58 am
by martinwuff
Fresh install of Raspbian on my Pi Zero. When running update, it gets past the archive.raspberrypi.org links pretty quick, then stalls for a while. First time through I couldnt get any mirrordirector links, second time the same, third time it seems to get the first 3 (contrib, non-free, and rpi armhf packages, but then sits at 100% [Waiting for headers] for a few minutes and then error, can't connect.
Posted: Fri Mar 03, 2017 10:28 am
by MarkDH102
I too have an up to date (as of last week) Jessie on a Pi3 and am struggling to install pycurl.
It took a good 5 minutes before the action completed...
sudo apt-get install python-pycurl
(stuck on waiting for headers)
Posted: Fri Mar 03, 2017 9:56 pm
by plugwash
I made some configuration changes this afternoon, please tell me if things have improved.
