30 pin EDP connection for display?
Posted: Fri Feb 17, 2017 2:49 am
by PlayableCharacterX
Hi!
I am new to Raspberry Pi, and I have a question that I could not find the answer for my self with Google.
Can Raspberry Pi use a EDP connection for Display? Say I want to use a 17" laptop screen replacement with a 30-pin EDP connection, can I get an adapter to use it with Raspberry Pi? Through the DSI-connector maybe?
Re: Getting started with Raspberry Pi - please help!
Posted: Fri Feb 17, 2017 9:51 am
by DougieLawson
To reuse laptop displays you need a LVDS to HDMI adapter board. Search on eBay with the device type/model of your display.
Re: 30 pin EDP connection for display?
Posted: Fri Feb 17, 2017 11:07 am
by Burngate
Google tells me you might mean Displayport. If so, https://www.lindy.co.uk/cables-adapters ... pter-p8455
Posted: Mon Feb 20, 2017 5:56 pm
Thank you guys! I figured it out. For anyone looking for the same; here's what I figured out:
Today, most laptop screens use a 30-pin eDP connection. If you would like to use this for one of your projects, you need a controller board for that specific screen. This will give you an HDMI input - which you can use with your Raspberry Pi 3 HDMI output.
For example:
http://www.ebay.com/itm/Novatech-L-Seri ... Swo4pYgjlR
This laptop screen is named B154EW01 - to find a suitable controller board, we have to search for: "B154EW01 Controller Board".
http://www.ebay.com/itm/VGA-LCD-Control ... SwcUBYSQ9M
Hope this was helpful for someone!
Good luck!
- PlayableCharacterX
