daveyjr1957
Pi 7" screen rotation problems
Mon Feb 13, 2017 11:46 am
Hi
I have my pi - screen and matching case (all for PiHut).
All working fine except that the screen image is upside down. The seller tells me that I need to enter LCD = 2 into the config file. I have tried to do this using leaf through the GUI but its read only. When I use terminal using 'sudo' I can not get it to move the the "Boot" directory.
Any advice greatly appreciated.
Dave
Re: Pi 7" screen rotation problems
Mon Feb 13, 2017 11:49 am
Add
lcd_rotate=2
into /boot/config.txt and reboot.
Use sudo nano /boot/config.txt in an LXTerminal window to edit it. If you can't work out how to do that hold or tap [SHIFT] during boot and use the NOOBS recovery system config editor to do it.
texy
Mon Feb 13, 2017 11:50 am
Hi and welcome to the forum.
The actual config line needs to be
lcd_rotate=2
I've never used leaf, but for nano from the CLI use
at the end of the file enter
lcd_rotate=2
Then enter Control-X and Y to agree to save (or something similar).
FYI the lcd_rotate=2 is correct for the official screen only.
Hope this helps,
Texy
daveyjr1957
Wed Feb 15, 2017 4:02 pm
Dear All
Thanks for the advice - support and yes that is it. :lol:
Still cant open and write without using sudo su , then opening nano?
But done now thanks.
