Page 1 of 2
Tip for command line / terminal use
Posted: Sat Sep 15, 2012 9:10 am
by The Captain
Well since there is no "tips" section I'll have to put such things here.
When you download a software source package they often have rather convoluted file names after you have unpacked it. Often the developer will get a bit carried away with the Dewey decimal version description.
For instance "name_1.20.3_beta_1"
In most cases you could rename it for convenience before make and install but here's a better idea;
1) unpack your new package to your home folder
2) Open a terminal
3) Instead of trying to type the entire excessive name_1.2.3_beta_1 for instance, just type -
cd na*
You can add the asterisk after a couple of characters as a wild card to fill in the rest for you.
It's nothing new but most people coming from Windows won't have used it before even though it works in an MSDOS command line too.
Re: Tip for command line / terminal use
Posted: Sat Sep 15, 2012 9:27 am
by joan
In the same vein you can type a few characters and then press esc esc space which will auto complete if unique. If not unique pressing esc esc tab will show a list of matches.
Posted: Sat Sep 15, 2012 11:33 am
by PocketSized
Would'nt pressing the tab-key also auto coplete? It does in "my" terminal.
If this thread catches on, I think it would be a good idea to edit the first post so it contains all the tips and tricks! :)
Posted: Sat Sep 15, 2012 12:10 pm
by PocketSized
Use the * with care! I guess changing directory is not that big of a deal but using it when you delete stuff could go horribly wrong, since typing rm na* would delete every file in that folder starting with na! Only use * when you need to refer to more than one file.
Using the auto complete option is always better when referring to one file. Pressing the tab key will auto complete for you as long as there is only one file matching what you are typing. I does in "my" terminal any way..
A tips/tricks thread is a good idea. But it needs to be updated frequently whit every good tip/trick in the first post. I guess you volunteered for that by starting this thread The Captain ;)
Posted: Sat Sep 15, 2012 4:00 pm
by The Captain
PocketSized wrote:Use the * with care! I guess changing directory is not that big of a deal but using it when you delete stuff could go horribly wrong, since typing rm na* would delete every file in that folder starting with na! Only use * when you need to refer to more than one file.
The trouble with Linux specific console commands is that they won't work via SSH, Webmin or any other form of remote terminal. Mine is a more compatible solution but yes it could do with a warning too.
Yes I'll happily merge all the tips on this subject into the first post when traffic settles along with attribution.
I'll drop a line to the mods about a "Tips" category although I think it would be complete chaos unless it was locked and someone kept it organised and tested them for safety ;) :D
Posted: Sun Sep 16, 2012 10:37 am
by Vassius
The Captain wrote: The trouble with Linux specific console commands is that they won't work via SSH, Webmin or any other form of remote terminal. Mine is a more compatible solution but yes it could do with a warning too.
Tab completion works just fine via SSH.
Posted: Sun Sep 16, 2012 11:03 am
by bredman
PocketSized wrote:A tips/tricks thread is a good idea. But it needs to be updated frequently whit every good tip/trick in the first post.
Information belongs in a wiki, discussion belongs in a forum.
Forums are poor places to store long-term useful information.
Posted: Sun Sep 16, 2012 11:14 am
by The Captain
Indeed but that's not how the world works as this site proves. Telling new users to RTFM will make them give up.
Posted: Mon Sep 17, 2012 9:47 pm
by mikerr
PocketSized wrote:Would'nt pressing the tab-key also auto complete? It does in "my" terminal.
Yes, and pressing tab twice will list all options...
Posted: Tue Sep 18, 2012 4:50 pm
by emcsquirreled
Just make sure you are in a bash shell. My Pi defaults to a different shell (when I SSH in, anyway), but typing "bash" fixes this.
Posted: Tue Sep 18, 2012 5:02 pm
by Joe Schmoe
Wrong. 'Nuff said.
Posted: Tue Sep 18, 2012 5:03 pm
by Joe Schmoe
I wonder what shell that was... (even 'ash' has filename completion these days)
Posted: Tue Sep 18, 2012 5:35 pm
by Hiro
Another useful tip. If you forget to add sudo at the start of a command that needs it simply type.
sudo !!
As the next line and this will repeat the last entered command as the root user (or super user if that is the preferred term).
Posted: Tue Sep 18, 2012 5:52 pm
by emcsquirreled
Joe Schmoe wrote:I wonder what shell that was... (even 'ash' has filename completion these days)
I'm not really sure what shell it is. Here is what the Pi says:
$ echo $SHELL
/bin/sh
What is this?
Posted: Tue Sep 18, 2012 5:58 pm
by jojopi
emcsquirreled wrote:/bin/sh
What is this?
dash. http://gondor.apana.org.au/~herbert/dash/
Posted: Tue Sep 18, 2012 6:02 pm
by emcsquirreled
jojopi wrote:dash.
Hmm. Where do I change this? I can do it in my login script, but it seems inefficient to start dash and then use it to load bash... :?
Posted: Tue Sep 18, 2012 6:09 pm
by jojopi
emcsquirreled wrote:Where do I change this?
"chsh -s /bin/bash".
(Or "sudo nano /etc/passwd" and edit the last field for the user in question.)
Posted: Tue Sep 18, 2012 6:13 pm
by k4gbb
Try editing your passwd file.
It specifies which shell is to be used when the user logs on.
<<Charley>>
Posted: Tue Sep 18, 2012 7:30 pm
by emcsquirreled
k4gbb wrote:Try editing your passwd file.
<<Charley>>
Thanks!
Posted: Tue Sep 18, 2012 7:31 pm
by emcsquirreled
Back to terminal tips, you can use the up and down arrows to cycle through previously typed commands. This is similar to !!, but it allows you to go farther back into your command history.
Posted: Thu Sep 20, 2012 2:02 pm
by thradtke
emcsquirreled wrote:Back to terminal tips, you can use the up and down arrows to cycle through previously typed commands. This is similar to !!, but it allows you to go farther back into your command history.
Worth noting is the search capability from readline library. CTRL-R does incremental backward search. History is saved, i.e. kept after bash quits.
Also, there are powerful editing commands like CTRL-U/K to chop of everything before/after the cursor. There's a lot to explore, and if you got used to it, you're ready for emacs :-).
Posted: Thu Sep 20, 2012 2:18 pm
by RaTTuS
history can be found in
~/.bash_history
~/ <- means your home directory
cd -
will take you to the last place you cd'ed from
ps axOT list all processes sorted by time
Posted: Thu Sep 20, 2012 3:17 pm
by jamesh
Nobody is EVER ready for EMACS.
Posted: Wed Mar 27, 2019 7:16 pm
by eccentricdyslexic
Been looking for a list of terminal tips, a friend once showed me a tip to list the previous used commands, but I can’t remember it! Any ideas?
Posted: Wed Mar 27, 2019 7:44 pm
by gkaiseril
'history' works for me in bash. To see them one by one use the up arrow command. One can read more about by using the man history command.
Difference between sh and bash will explain the difference between bash and the shells.
The man command will be with your system even when not connected to the internet. It is a good tool to learn how to use.
