Pin that is in powered on OSMC shutdown
Posted: Wed Feb 08, 2017 5:07 pm
by silent001
Good day, I am trying to find a pin to give out power when the Raspberry Pi 3 V1.2 is on but when you power off within OSMC that pin must also be powered off. Please help I have searched but I can't find what I am looking for
Re: Pin that is in powered on OSMC shutdown
Posted: Wed Feb 08, 2017 7:02 pm
by rpdom
I don't know if it will work with OSMC (it should do), you can set an option in /boot/config.txt to make almost any gpio pin a power signal pin.
Info:   Drives a GPIO high or low on poweroff (including halt)
Load:   dtoverlay=gpio-poweroff,<param>=<val>
Params: gpiopin                 GPIO for signalling (default 26)
        active_low              Set if the power control device requires a
                                high->low transition to trigger a power-down.
                                Note that this will require the support of a
                                custom dt-blob.bin to prevent a power-down
                                during the boot process, and that a reboot
                                will also cause the pin to go low.
So, if you want to use say pin 29 (GPIO 5) as the controlling pin, you'd put
dtoverlay=gpio-poweroff,gpiopin=5,active_low=1
in /boot/config.txt
As gpios 0-7 pull high by default, that pin will be high at boot and stay that way until the Pi is shutdown, when it will go low. Note that it will also go low during a reboot.
Posted: Thu Feb 09, 2017 6:26 am
by silent001
Thanks rpdom but I don't think you understood what I meant. Lets say I want to connect a LED to the Raspberry Pi 3 Modal B V1.2 but I want the LED to only be on as long as OSMC is on not as long as the board gets power. So for as long as OSMC is running the LED must be on. If I go into OSMC and select power off inside OSMC the LED must turn off as soon as the sytem is off.
Posted: Thu Feb 09, 2017 10:21 am
by rpdom
silent001 wrote:Thanks rpdom but I don't think you understood what I meant. Lets say I want to connect a LED to the Raspberry Pi 3 Modal B V1.2 but I want the LED to only be on as long as OSMC is on not as long as the board gets power. So for as long as OSMC is running the LED must be on. If I go into OSMC and select power off inside OSMC the LED must turn off as soon as the sytem is off.
Yes, that's exactly what that option does, as long as OSMC performs a normal shutdown of the Pi. Note I said "shutdown" not "remove power".
Posted: Thu Feb 09, 2017 12:07 pm
by silent001
Thanks rpdom
So my config.txt will look as follows?
gpu_mem_1024=256
hdmi_ignore_cec_init=1
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
Is this correct? If so and I want to connect a multimeter to it do I connect it to ground and GPIO05 like in the attached picture?
Thanks once again
Posted: Thu Feb 09, 2017 12:28 pm
by rpdom
Yes, that is correct.
Posted: Thu Feb 09, 2017 1:22 pm
by silent001
It doesn't work. I get full 3.12 Volts on it even if I use the shutdown Inside OSMC
Posted: Thu Feb 09, 2017 1:53 pm
by silent001
I tested it in raspbian and it works but the shutdown doesn't complete. Please help. I can't figure out whats wrong
Posted: Thu Dec 21, 2017 4:45 am
by tifon420
Thanks rpdom
gpu_mem_1024=256
disable_overscan=1
start_x=1
disable_splash=1
gpu_mem_256=112
sdtv_aspect=1
gpu_mem_512=144
Thanks once again
I need to try this on mine! I hope I don't get the same shut-down issue he experienced... I will update tomorrow.
Posted: Sat Sep 15, 2018 4:50 pm
by Ryan780
Anybody ever get this working? I am having the same problem with OSMC. No matter what pin I use it is always 3.3v if the Pi has power, regardless of the whether it is running or not.
