RasPiGuy12345
UV4L on Startup
Tue Feb 07, 2017 3:39 pm
Hello Community,
I am currently looking into a script on startup of a Raspberry Pi that would start a UV4L stream. Currently I need to go into terminal and run a command, but would like to have this automated if possible.
I have seen other posts talking about startup scripts, but nothing similar to what I'm looking for. Any insight or help would be great.
~PiGuy
Re: UV4L on Startup
Tue Feb 07, 2017 7:19 pm
sudo nano /etc/systemd/system/uv4l.service
[Unit]
Description=uv4l daemon service
[Service]
ExecStart=/usr/local/bin/script_to_run_uv4l_goes_here
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=uv4l
[Install]
WantedBy=multi-user.target
sudo systemctl enable uv4l.service
sudo systemctl start uv4l.service
Job done. Time for a beer.
This is a doctor free zone.
RasPiGuy12345
Re: UV4L on Startup
Wed Feb 08, 2017 2:46 pm
Thank you for the quick reply! I see the part where you say to insert the script to run, but how exactly do I create that script? Is it just entering the command I would run in terminal, and save it as a script?
Sorry for this, but I am a complete Pi noob :(
Re: UV4L on Startup
Wed Feb 08, 2017 6:25 pm
RasPiGuy12345 wrote: Is it just entering the command I would run in terminal, and save it as a script?
You gave no clues as to what you're running. It is whatever command you type on a command line.
pulurobotics
Re: UV4L on Startup
Sun Mar 18, 2018 8:59 am
Would this work?
Check where your uv4l is installed and replace leading path with it.
/usr/bin/uv4l -nopreview --auto-video_nr --driver raspicam --encoding mjpeg --width 640 --height 480 --framerate 10 --server-option '--port=9090' --server-option '--max-queued-connections=30' --server-option '--max-streams=5' --server-option '--max-threads=29'
