ujjwalrathod007
sudo raspi-config
Sat Jan 07, 2017 9:19 am
I want to enable VNC server. I have 2016-05-10-raspbian-jessie. I don't see the option for it. Can anyone has idea why?
Re: sudo raspi-config
Sat Jan 07, 2017 9:26 am
ujjwalrathod007 wrote:I want to enable VNC server. I have 2016-05-10-raspbian-jessie. I don't see the option for it. Can anyone has idea why?
Raspbian Jessie with Pixel Desktop Blog:
https://www.raspberrypi.org/blog/introducing-pixel
Retired disgracefully.....
......to an uncomplicated life !
ujjwalrathod007
Sat Jan 07, 2017 12:11 pm
I tried the commands
sudo apt-get dist-upgrade and
sudo apt-get update
But the 1st one doesnt work properly and gives an error that software stoped unconditionally
Sat Jan 07, 2017 12:17 pm
ujjwalrathod007 wrote:I tried the commands
sudo apt-get update
You run update first, regards RealVNC it is discussed towards end of Blog.......
Martin Frezman
Sat Jan 07, 2017 12:22 pm
You have to do them both, but in the opposite order.
So:
$ sudo bash
# apt-get update
# apt-get dist-upgrade
# apt-get install rpi-chromium-mods python-sense-emu python3-sense-emu python-sense-emu-doc realvnc-vnc-viewer realvnc-vnc-server
# reboot
The thing to note is this: Although the realVNC stuff comes installed with a *new* install of Raspbian, you have to explicitly install it when you're doing an upgrade type install.
If this post appears in the wrong forums category, my apologies.
Sat Jan 07, 2017 12:23 pm
Martin Frezman wrote:You have to do them both, but in the opposite order.
So:
$ sudo bash
# apt-get update
# reboot
Yes it is all covered in the Blog, the OP needs to read it ALL........
ujjwalrathod007
Sat Jan 07, 2017 8:36 pm
I have tried them as per the sequence. I don't know why second command gives me an error.!!
first one asks me to run sudo dpkg --config -a
and after I run second It takes a long time and then stops...
ujjwalrathod007
Sun Jan 08, 2017 8:50 pm
Let me tell the sequence.
First I do sudo apt-get update and after that when I run sudo apt-get dist-upgrade it will tell me that dpkg was intrupted. you must manually run 'sudo dpkg --configure -a' to correct the problem.
after that I run 'sudo dpkg --configure -a' which is OK!! then sudo apt-get dist-upgrade
[email protected]:~ $ sudo dpkg --configure -a
Setting up initramfs-tools (0.120+deb8u2) ...
update-initramfs: deferring update (trigger activated)
Setting up systemd (215-17+deb8u5) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
/var/lib/dpkg/info/systemd.postinst: 150: /var/lib/dpkg/info/systemd.postinst: cannot open /run/systemd/was-enabled: No such file
Setting up libpam-systemd:armhf (215-17+deb8u5) ...
Processing triggers for initramfs-tools (0.120+deb8u2) ...
[email protected]:~ $ sudo apt-get dist-upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
The following packages have unmet dependencies:
systemd-sysv : Depends: systemd (= 215-17+deb8u4) but 215-17+deb8u5 is installed
E: Unmet dependencies. Try using -f.
nastybuttler322
Sun Jan 08, 2017 8:58 pm
click on the raspberry button that is the equivalent of the windows start button.
Move the pointer over preferences.
Move the pointer over the raspberry called Raspberry Pi Configuration.
Click on the interfaces tab.
From there you can enable VNC, SSH, etc..
ujjwalrathod007
Mon Jan 09, 2017 3:19 pm
I dont have monitor.. I am doing ssh to it.
While doing Sudo apt-get dist upgrade the pi is getting disconnected....
Return to “Beginners”
