Vairetz
USB gps problem
Fri Jan 06, 2017 12:40 am
Hi everyone I'm trying to use Raspberry Pi 2 as navigation system. I installed Navit and I bought an usb gps module. (U-blox 7 VK-172)
Gps is paired as ttyACM0 so I try this command for work gps with gpsd:
sudo gpsd /dev/ttyACM0 -F /var/run/gpsd.sock
Now I have a problem,sometimes it works perfectly (rarely) but sometimes Navit doesn't recive the signal.. What is the problem?
I made a site with a raspi projects' collection, my idea is sharing my projects with other people.
My web site is https://raspiproject.altervista.org/ I hope you like it and you want work with me
scotty101
Re: USB gps problem
Fri Jan 06, 2017 9:19 am
Difficult to tell. Are you sure that the GPS has a good position fix?
evilskaap
Re: USB gps problem
Fri Jan 06, 2017 9:33 am
You can use cgps or xgps as test clients for gpsd to get more detailed info about the gps and its lock state.
Install via sudo apt-get install gpsd-clients python-gps
Vairetz
Re: USB gps problem
Fri Jan 06, 2017 8:42 pm
I test the gps using minicom, GPS seems to work but navit doesn't recive the signal. Also the usb doungle's led doesn't blink
jksmith
Re: USB gps problem
Mon Jan 09, 2017 8:29 am
You should check with cgps to see if you get the data. If not, your problem is with gpsd (and we can dig).
You can also try to configure Navit to read directly from the device and bypass gpsd :
 <vehicle name="Direct" enabled="yes" source="file://dev/ttyACM0" active="1"/>
(more details at http://wiki.navit-project.org/index.php ... le_Options )
Vairetz
Re: USB gps problem
Mon Jan 16, 2017 3:59 pm
I've already configured Navit, now I try with cgps and I'll give you updates
