calleblyh
RPi Zero, faulty USB-port, ENC28J60 pinout to GPIO pins
Tue Jan 03, 2017 10:23 am
As I have earlier told I bricked my PiZero USB-port. However I can still via serial and Putty connect to it on my LapTop. Also trying to connect a ENC28J60 to get internet to work. There is a small problem, the labelling on the board is different from guides I have found on the web. But I think via trial and error method I will find a solution
Another thing when connecting via serial , is it possible to get the terminal screen on the PiZ HDMI output to update in parallel with my LapTop Putty screen.
An interesting 2017 infront of us
Re: RPi Zero, faulty USB-port, ENC28J60 pinout to GPIO pins
Tue Jan 03, 2017 10:48 am
The pin layout is the same as every other 40-pin Raspberry. With the front face (where the HDMI & USB connectors are sited towards you) Pin #1 is first on the left with pin #2 behind it.
https://pinout.xyz
This is a doctor free zone.
gregeric
Tue Jan 03, 2017 10:58 am
It's likely the ENC28J60 module whose pinout is in doubt - especially considering the OP has managed to hook up a serial connection without a hitch.
Post a picture of your module.
Dougie's a linux wizard, so I'm pretty sure that if there is a way, he can advise how to get the serial console input appearing on HDMI. Maybe using screen -x, auto started somehow?
Tue Jan 03, 2017 11:08 am
This is what both of mine look like.
SO == MISO == GPIO10 Pin#19
SI == MOSI == GPIO09 Pin#21
CS == CE1 == GPIO07 Pin#26
CLK == SCLK == GPIO11 Pin#23
INT == INT == GPIO25 Pin#22
VCC == 3V3 == Pin#1 or Pin#17
GND == GND == Pin#6, Pin#9, Pin#14, Pin#20, Pin#25, Pin#30, Pin#34 or Pin#39
I've no idea how to get the serial stuff to mirror on to /dev/tty1. Probably screen -x ... may work.
gregeric
Tue Jan 03, 2017 12:11 pm
As an alternative to trying to mirror the serial console on HDMI, and when you have your SPI ethernet module working, you might consider using sudo apt-get install synergy to share your laptop keyboard & mouse over the network, thus recovering some functionality lost by way of your dead USB port.
calleblyh
Tue Jan 03, 2017 4:50 pm
Thanks for all responses. Attached a picture of my ENC28j60, actually the same as I found on Raspi.tv, so the 2*6 header
5V - GND
INT - CLK INT label I am not sure could be LNT ?
SO -WOL WOL ? stands for ?
SCK - ST
RST - CS
Q3 - GND Q3 ? stands for ?
enc28j60 resize 40.jpg (20.62 KiB) Viewed 5511 times
In the meanwhile connecting 5V to ENC I can see flashing Yellow LED on the ethernetconnector when connected to my router. Using 3,3V no flashing. So, should I use 3.3V or 5V
also I think there is a typing error in previous response
SO == MISO == GPIO09 Pin#21 and not SO == MISO == GPIO01 Pin#17 as said in response
karrika
Tue Jan 03, 2017 5:41 pm
These pin numbers are so confusing.
CE0 = GPIO 8 = #24
MISO = GPIO 9 = #21
MOSI = GPIO 10 = #19
SCLK = GPIO 11 = #23
INT = GPIO 25 = #22
GND = GND
VCC = 3.3V
At least PiZero works by simply adding one line to /boot/config.txt
dtoverlay = enc28j60
If you want to remote control your desktop with a keyboard and mouse you could have a look at TeamViewer or VNC. They both allow you to run almost anything on PiZero while controlling it from your laptop's keyboard and mouse.
Adafruit also has a RetroPie addition for mapping GPIO pins to keyboard shortcuts. Most console games work well with up/down/left/right and a few fire buttons.
Tue Jan 03, 2017 5:54 pm
calleblyh wrote:Thanks for all responses. Attached a picture of my ENC28j60, actually the same as I found on Raspi.tv, so the 2*6 header
5V - GND
SCK - ST
RST - CS
Your photo is too fuzzy. Post a full size version on http://imgur.com post the link on here.
WOL == Wake on LAN
INT == interrupt == GPIO25 for the standard driver
I'd guess that ST is actually SI == MOSI
No ideas on Q3.
gregeric
Tue Jan 03, 2017 6:08 pm
karrika wrote:These pin numbers are so confusing.
If you exclude Dougie's error strewn list it makes sense. But his pictures are OK at least.
Tue Jan 03, 2017 6:20 pm
Fixed it.
calleblyh
Wed Jan 04, 2017 12:50 pm
Thanks for all contributions, I finally made it, I got an IP-adress.
This is my interconnection pinout
RPiZero GPIO #--------------------ENC28J60 PinLabel
17----------------------------------------- Q3 3,3v
19------------------------------------------ST
21------------------------------------------SO
22------------------------------------------INT
23------------------------------------------SCK
24------------------------------------------CS
25------------------------------------------GND
How about the mirroring feature screen -x, need to add it into autostart or /boot/config.txt. I couldnot find any help related to mirroring using screen -x
gregeric
Wed Jan 04, 2017 1:20 pm
Great job! That "ST" label is probably meant to be "SI".
The screen -x hint was just that, an idea that it might be used to do as you wish. I haven't attempted to do it myself, but essentially you'd start a screen session in your serial console with screen -S myScreen bash. The next bit I'm not certain about how to make work, but I imagine an autostarted bash script, looping while looking for a screen session named myScreen. If it exists, the script runs screen -x myScreen & hopefully that will run in /dev/tty/0, providing a mirrored display of the myScreen serial console session on the HDMI output. I'm pretty sure I could make that work in an auto-started LXTerminal, but not so sure without the desktop running.
My second thought, using synergy to provide keyboard & mouse over network is what I'd use instead (others have suggested vnc etc), but those may only work if you are autostarting the Pixel desktop.
karrika
Wed Jan 04, 2017 2:33 pm
You could try to first allow x on the PiZero.
xhost +localhost
After that ssh into the PiZero and start a terminal with the display on PiZero.
DISPLAY=:0.0 lxterminal
I have not tried this...
