BigJeffIE
Running Idle as root from desktop
Sun Sep 09, 2012 7:09 pm
Hi folks,
I'm using IDLE to have a go at programming in Python. Even though there's an icon on the desktop I can't use it because I need it to run as root.
How do I get the icon to run as root instead of having to open a terminal window and doing sudo idle.
Thanks,
Chris
JeremyF
Re: Running Idle as root from desktop
Sun Sep 09, 2012 10:57 pm
Hi Chris!
You can create a very simple bash script to do this:
  • 1. Open a terminal
    2. type cd ~/Desktop
    3. type touch IDLE_as_root
    4. type nano IDLE_as_root
    5. type in sudo idle
    6. exit nano
    7. type in sudo chmod +x IDLE_as_root
    8. Close terminal
    9. Double click on the IDLE_as_root program on your desktop
{sig} Setup: Original version Raspberry Pi (B, rev1, 256MB), Dell 2001FP monitor (1600x1200), 8GB Class 4 SD Card with Raspbian and XBMC, DD-WRT wireless bridge
BigJeffIE
Mon Sep 10, 2012 9:02 am
and thanks again Jeremy.
This will make life easier.
Regards,
Chris
legaborgo
Fri May 03, 2013 6:54 am
I liked this only: (change: sudo idle)
/usr/bin/gksu -u root idle
legaborgo
layer7
Thu Dec 05, 2013 2:00 pm
If you want to always run IDLE with root privs then simply edit the desktop link entry in ~/Desktop and change the following line:
Exec=/usr/bin/idle
to
Exec=sudo /usr/bin/idle
You will then be able to just open idle in the normal way from your desktop and it will have root privs.
pythonnoob123
Fri Jul 04, 2014 11:22 am
"simply edit the desktop link entry in ~/Desktop and change the following line:
Exec=/usr/bin/idle
to
Exec=sudo /usr/bin/idle"
how do I do that? I'm a total noob.
Mamvcivm
Tue May 03, 2016 8:43 pm
layer7 wrote:If you want to always run IDLE with root privs then simply edit the desktop link entry in ~/Desktop and change the following line:
Exec=/usr/bin/idle
to
Hi,I did this by opening the properties of the IDLE file in /home/pi/Desktop. I went to the Desktop Entry tab and prefixed the command with sudo, ie sudo /usr/bin/idle3 for Python 3 (IDLE), however this didn't work.
Any advice please?
Cheers,
Andy
penguinmanraspberry
Mon May 01, 2017 4:39 am
Both 'Solutions' in this thread do not work.
The first solution 'create a text file link on the desktop' won't execute anything it will just open the text file with an editor.
The second solution recommends editing a file in ~/Desktop that doesn;t exist.
We require a right-click context menu that says 'Create shortcut'
Do it.
B.Goode
Mon May 01, 2017 9:10 am
With apologies if you have a specific requirement and already know better, but things have moved on a lot since this topic was opened nearly 5 years ago, and for many purposes there is no longer a need to run Idle as root. Are you sure you actually need to do this?
