Mar_56
Timer Interruption
Tue Dec 20, 2016 5:07 pm
I'm new on Raspberry. I wanted to know if it is possible to execute a code every 10 ms (for example) ? On an arduino board, I used timer interruption to do that with the following libray (#include <avr/interrupt.h), and use some prescaler etc.... I need that for servo motor control, or display some data (temperature, speed...) at a specific frequency.
If anyone have a very short example, and very simple, it would be good :)
For example, I want to display in the time in the console at every 100 ms. For now I used some delay in the main function, but it is not appropriate... because the code stop on the delay...
Thanks!
RichInTheUSA
Re: Timer Interruption
Tue Dec 20, 2016 7:31 pm
There are java tutorials on concurrency, with sleep timers. Sorry cant be more help... not sure what language you are coding in.
https://docs.oracle.com/javase/tutorial ... sleep.html
Mar_56
Tue Dec 20, 2016 9:11 pm
Thanks for the response :) For the language I prefer to used C programming...
