Computerring123
SSH headless enable
Sun Dec 18, 2016 10:44 pm
I dont understand how to put ssh file to boot partition /boot/ of sd card to enable ssh. How to browse boot partition? Can i browse it like if i normally put something to sd card? What kind of file i have to apply? txt or rtf or what. video of this could be good. i really need complete guide of this
e: im talking about this :
https://www.raspberrypi.org/documentati ... ccess/ssh/
https://www.raspberrypi.org/blog/a-secu ... /#comments
demoz
Re: SSH headless enable
Sun Dec 18, 2016 10:51 pm
Hello there,
I am not sure what you are doing there... But from what i see you are doing it wrong.
To enable ssh service you can edit 2nd partition (not boot) and append following to /etc/rc.local :
/etc/init.d/ssh start
BEFORE exit.
Example how it should look :
# Print the IP address
_IP=$(hostname -I) || true
if [ "$_IP" ]; then
  printf "My IP address is %s\n" "$_IP"
fi
exit 0
Above command will start the ssh daemon on boot.
I am not sure if you can access the 2nd partition on windows without using 3rd party tool - you should google for this.
Bitcoin: 1KWVA9qBfTHmzPMvDw4ociqnk71FoLm1mp
https://vaskir.co - check my website :)
Martin Frezman
Sun Dec 18, 2016 11:00 pm
Here's the simple answer.
On windows, insert the card into whatever slot you are using (either something on the main system or in a USB slot). Figure out, using whatever tools you are comfortable with, what drive letter the SD card is (will usually be something like F:) Below, I will assume it is F:.
Press Windows Key and r at the same time. At the "Run" prompt, enter "cmd" (without the quotes) and hit enter.
At the C> prompt (or whatever it is), type "dir F:" and hit enter.
You will see a bunch of files.
At the C> prompt, type: "echo.>F:\ssh" and hit enter.
Now do whatever it takes to "safely remove" the SD card from the Windows machine.
Take the card and boot it on the Pi.
If this post appears in the wrong forums category, my apologies.
klricks
Mon Dec 19, 2016 1:17 am
Computerring123 wrote:I dont understand how to put ssh file to boot partition /boot/ of sd card to enable ssh. How to browse boot partition? Can i browse it like if i normally put something to sd card? What kind of file i have to apply? txt or rtf or what. video of this could be good. i really need complete guide of this
1. Start Notepad (In Windows Accessories) You can type random text or leave the file empty
2. Save with filename: ssh
(or ssh.txt also works if you have the latest updates).
3. Drop the ssh file into /boot.
4. Boot the SD card in RPi.
Note that the ssh file will be deleted after successful enable / boot.
Martin Frezman
Mon Dec 19, 2016 2:28 am
Note that this method (using Notepad) is dangerous, because of both of the following facts:
1) You will usually create a file with a .txt extension (which you don't want).
2) The fix that you allude to, where ssh.txt is also recognized as a magic filename, is new and may not be present on any given install. I.e., if you haven't downloaded the very latest and greatest, you won't have it.
In my crystall ball, I see a lot of very confused postings coming up on these boards where people follow instructions that get them a file named "ssh.txt" (with the .txt extension) and are confused that it doesn't work (as some of the latest and greatest tuts assure them that it will) - because they don't have the latest version of the software.
In short, you can't beat the command prompt. Follow my instructions and you'll never get a .txt file (unless you really want one).
klricks
Mon Dec 19, 2016 5:28 am
Martin Frezman wrote:Note that this method (using Notepad) is dangerous, because of both of the following facts:
I edited my post to be more clear. I did not know that the ssh.txt was added later. I tend to do updates once or twice a week.
sudo apt-get update
sudo apt-get upgrade
The .txt extension problem is caused by the MS default setting to hide extensions of known (registered) file-types. This has always led to confusion. I disable that setting on all my Windows systems.
Martin Frezman
Mon Dec 19, 2016 9:26 am
Not really. The .txt extension problem is caused by the fact that notepad, by default, reads and writes files with a .txt extension. Basically, the Windows world is not happy with files without extensions. Effectively, files without extensions are like travelers without passports - they have no identity in the Windows worldview. The "hide extensions" mis-feature just makes it worse, by preventing the user from seeing what's wrong, but the underlying problem is really notepad itself (and the whole philosophical underpinning of Windows).
Really, this whole "let's disable ssh" thing has been a boondoggle. The programming to support it (e.g., the "ssh" file in /boot thing) seems very hit-and-miss (and they don't seem to be done yet). I think they're beginning to rue the day they ever came up with the idea of disabling ssh, and will probably completely reverse (undo) it pretty soon.
Martin Frezman
Mon Dec 19, 2016 12:54 pm
And I should add to the previous that another issue with this scheme is that catering to ".txt" is arbitrary. What about people who've never used Notepad (which, i think, is most Windows users), but who only use Word? So, now we have to check for "ssh.doc" as well. And what about the Excel users? And the PowerPointers?
The list goes on and on.
And what about the Mac users? I'd imagine that they have a whole 'nother set of extensions to consider.
HawaiianPi
Mon Dec 19, 2016 11:11 pm
Martin Frezman wrote:Really, this whole "let's disable ssh" thing has been a boondoggle. The programming to support it (e.g., the "ssh" file in /boot thing) seems very hit-and-miss (and they don't seem to be done yet). I think they're beginning to rue the day they ever came up with the idea of disabling ssh, and will probably completely reverse (undo) it pretty soon.
That is so not going to happen. The changes are here to stay. They are working quickly to resolve the issues that people are discovering with the new system, and those fixes will be included in the next image release. Until then we'll just have to deal with them.
Although I must say I am surprised someone who doesn't even know how to create a simple file would be interested in using SSH. No offence to the OP, I understand some people here may be less experienced with computers in general, and new to Linux as well. It's just that SSH is a rather limited and somewhat cryptic interface. It's not designed to be easy.
Computerring123
Tue Dec 20, 2016 5:28 pm
Martin Frezmans guide success. Thx.
Anchan
Thu Dec 22, 2016 6:44 pm
https://youtu.be/S1UHoTQn11Y
The Above Video has the all the solution to enable ssh in raspbian.
Martin Frezman
Fri Dec 23, 2016 12:17 am
Anchan wrote:https://youtu.be/S1UHoTQn11Y
Hardly seems necessary, seeing as how my method:
a) Works fine
and
b) Is obviously the best way to do it.
liontooth
Sat Jan 07, 2017 8:50 pm
Hi Martin,
[quote="Martin Frezman"]
Two questions:
* Do you really need a period between echo and >?
* Shouldn't you write the ssh file to F:\boot\ssh?
Cheers,
David
Sat Jan 07, 2017 8:59 pm
liontooth wrote:Two questions:
If I remember DOS command line stuff correctly, Yes.
[/quote] * Shouldn't you write the ssh file to F:\boot\ssh?[/quote]
No.
/boot is where the first partition is mounted in Linux.
Windows doesn't understand anything Linux and just calls if F:\ or something similar
Martin Frezman
Sat Jan 07, 2017 9:18 pm
No.
Right.
1) The short answer is "not really". echo "just about anything" would work, since the contents of the file is irrelevant. "echo." is the time-honored way of putting out just a blank line in DOS batch files. If you leave out the dot, then you will get the string "ECHO is on." in the file - which, as I said, doesn't hurt anything, but looks kinda silly.
2) Correct. The root level (F:\) in DOS/Windows gets mounted as /boot under Raspbian.
liontooth
Sat Jan 07, 2017 9:29 pm
Perfect, thanks.
mfa298
Sun Jan 08, 2017 3:37 pm
Martin Frezman wrote:Here's the simple answer.
I've got to add that this sort of approach is probably the safest way to always get a file called ssh. Although rather than the "echo.>F:\ssh" step I've used
copy nul f:\ssh
(nul is roughly the DOS equivalent to /dev/null, but in this case it results in a zero length file)
Martin Frezman
Sun Jan 08, 2017 3:39 pm
6 of one, half dozen of the other.
The echo method is less typing.
It's almost like, the less you want in the file, the more typing you have to do.
dwasifar
Fri Nov 23, 2018 3:28 pm
Waking up an old thread to give my opinion.
I recently dug out my old Pi B and flashed the SD with Stretch Lite. Initially I found that after each reboot I would have to issue service ssh restart locally before being able to connect remotely via ssh. It never occurred to me that ssh might actually be disabled until I found this thread.
I'm starting ssh in rc.local now and that works fine, although it feels a little kludgy. But really, why would you want to disable ssh on the Lite version, which has no GUI? I can kind of understand it for the full versions; I don't agree with it but I see why one might do it. But there's no advantage to locking the user out of remote CLI on a system that can only be administered by CLI.
DirkS
Fri Nov 23, 2018 3:37 pm
It's not a matter of usefulness or convenience but plain and simple security.
In the 'olden days' it was enabled by default with a default user and password, so everybody with access over a network could easily log in.
If you have a problem with that then you can easily spin your own image using e.g. pi-gen
I assume you changed a setting somewhere that's the cause of your problems (which, BTW are *not* related to headless setup)
mfa298
Fri Nov 23, 2018 3:48 pm
This has been the default for a few years and the reasons are well documented. At the time the change was made there was a large number of people finding their pi's quickly became very slow as they were being taken over and used by 3rd parties for nefarious purposes.
Your method might feel kludgy because it is. There are several non kludgy methods described for enabling SSH on https://www.raspberrypi.org/documentati ... ccess/ssh/
dwasifar
Fri Nov 23, 2018 11:22 pm
Why would you assume that? I changed a setting to SOLVE the problem, which was that ssh is unexpectedly disabled "out of the box." I'm accustomed to actual Debian, which is not set up that way. If you install ssh on Debian with apt, the resulting installation works without needing a separate step of enabling it.
dwasifar
Fri Nov 23, 2018 11:23 pm
So basically it's an attempt at idiotproofing. :) People were careless with passwords and firewalls because they didn't know any better, and the decision was made to kneecap ssh to protect those users.
As I mentioned, I hadn't used this Pi in some time; the change must have been made since I used it last, because I don't remember having to go through this before.
I haven't looked at the link, but I imagine they involve unmasking the service in systemd. I suppose I could do that too.
mfa298
Fri Nov 23, 2018 11:44 pm
Things change over the course of 2-3 years, This particular change was at least two years go (look at the dates of the first posts in this tread).
not even that, maybe you should read the docs before complaining, they were even linked to from the first post in the thread.
But then x86 debian will also ask you to configure a user/ root password during the install. Raspbian (and most pi operating systems) have a well know default user and password which the bots are scanning for all the time.
dwasifar
Sat Nov 24, 2018 12:21 am
Fair enough, I suppose, but I would think the obvious solution to that would be to not have a default user and password, rather than disabling a basic service. It's like if every house came with the same set of keys, and the proposed solution to the resulting burglary problem was to seal off the doors rather than change the locks.
I did read the docs and comments on your suggestion, and it looks like quite a lot of the commenters agreed at the time that it would be better to force the user to pick a password on first boot.
