flaghacker
Share internet to RPi over USB
Sat Dec 17, 2016 9:50 pm
Hey guys!
I have a Windows 10 laptop connected to the internet, and I have a RPi zero connected to that laptop using a USB cable. Is it possible to share the network connection from my laptop to the RPi?
When I try to ping something this is the result:
I have already tried to enable network sharing on the RPi ethernet adapter:
But that doesn't work.
This is the result of "ip addr show":
and I can ping that IP address "169.254.102.139" from my laptop. I can not ping my laptops' IP from the RPi though.
Do you guys have any ideas on how to solve this problem? If you need any more info, feel free to ask!
Re: Share internet to RPi over USB
Sat Dec 17, 2016 9:56 pm
flaghacker wrote: I have a Windows 10 laptop connected to the internet, and I have a RPi zero connected to that laptop using a USB cable. Is it possible to share the network connection from my laptop to the RPi?
Will not work as both USB Ports are Slaves, you will need to put the Raspberry Pi in Gadget (Master) Mode:
http://blog.gbaman.info/?p=791
Last edited by fruitoftheloom on Sat Dec 17, 2016 10:01 pm, edited 2 times in total.
Retired disgracefully.....
......to a more gentile life !
flaghacker
fruitoftheloom wrote:
flaghacker wrote:...
Yes I did that, I can successfully SSH into it.
drgeoff
fruitoftheloom wrote: Will not work as both USB Ports are Slaves, you will need to put the Raspberry Pi in Gadget (Master) Mode:
USB ports on Windows PCs are always USB hosts (=masters). You need the RPI in Client mode (=gadget mode.)
Sat Dec 17, 2016 10:02 pm
The Windows Machine will then install a RNDIS Driver for the USB Network Interface and in Windows enable Internet Sharing and it should autmagically assign IP Addresses
Sat Dec 17, 2016 10:03 pm
YES I GOT IT THE WRONG WAY ROUND, YET AGAIN :oops: :oops: :oops: :oops: :oops: :oops: :oops:
drgeoff
Sat Dec 17, 2016 10:04 pm
Did you reboot the Zero AFTER setting up Internet Connection Sharing on the PC?
flaghacker
Sat Dec 17, 2016 10:09 pm
I think I did, but I just tried again to be sure. I still doesn't work.
Sat Dec 17, 2016 10:15 pm
Did you give the RPi Zero a static IP Address ?? it is probably easier to let Windows assign IP Addressing.......
Did you set up Windows Internet Connection Sharing correctly ?
Laptop WiFi - ICS - Laptop USB - USB Cable - RPi 0
flaghacker
Sun Dec 18, 2016 8:38 pm
fruitoftheloom wrote: Did you give the RPi Zero a static IP Address ?? it is probably easier to let Windows assign IP Addressing.......
Where do I need to give it an IP address? I tried doing it in the network and sharing center for the Rapberry PI's Network adapter:
But it still doesn't work. Do I need to set it in the RPi too? And if so, how?
fruitoftheloom wrote: Did you set up Windows Internet Connection Sharing correctly ?
Well I don't really know how to check it, and what do you mean with the "-" stuff?
recklessfb
Sun Jan 01, 2017 6:07 pm
I was having the same problem. This is what did it for me. https://learn.adafruit.com/turning-your ... net-tweaks
As mentioned in the article adding those lines are very important.
    auto lo usb0
    allow-hotplug usb0
    iface usb0 inet manual
Good luck.
