Used wrote:I have a rasberry pi 3 B and i would like to plug my 5V , 240ma fan. How should I plug my fan and since the recommanded max current from a pin is 0.16a ?
Just a Idea for controlling a 5v fan on the Pi .Using only the 5v rail
Using a transistor, withe the base switched by a Thermistor and
Trimmer, To run fan continua's but a switch across the thermistor
5+----------( fan )--------------------------- (c Transistor e )-----------0v-
5+-----( Thermistor)-----( Trimmer )----------( b )
---------( Switch )
Connect switch across Thermistor
Make shour trimmer go se no lower than 440r
Do research for Thermistor type
