zx5000
Pixel workspaces
Fri Dec 09, 2016 2:20 pm
I installed a recent Raspbian/Jessie on my RPi3 and the Pixel desktop only has one workspace. Is there a way to add more? None of the preferences menu include this.
Thanks in advance.
Jeff
PeterO
Re: Pixel workspaces
Fri Dec 09, 2016 2:43 pm
My Raspbian setup notes say "install obconf to setup desktops and change mouse focus rules".
PeterO
iw1
Fri Dec 09, 2016 7:00 pm
To increase the number of desktops:
Click middle mouse-button on desktop; left-click on 'Add new desktop'.
You can switch between desktops from this same menu.
Optional: to add desktop identifier to taskbar:
Right-click on taskbar and select 'Add / Remove Panel Items'.
Click 'Panel Applets'
In 'Panel Applets' window click 'Add'
In 'Add plugin to panel' window select 'Desktop number / Workspace name' (scroll down to near bottom of list)
Click 'Up' or 'Down' to move it to desired position on the taskbar
Add and move a spacer by the same method if you wish
Then click 'OK'.
If your mouse doesn't have a middle button the old way to achieve to add desktops is by editing a file:
In Filemanager: show hidden files
Open /home/pi/.config/openbox/lxde-pi-rc.xml in a text editor.
Find <desktops> and set to required number (e.g.2)
Re-boot.
PeterO
Fri Dec 09, 2016 8:24 pm
iw1 wrote:
If your mouse doesn't have a middle button ....
install obconf and use that.... :roll:
PeterO
zx5000
Fri Dec 09, 2016 11:31 pm
Yes I only have a trackpad keyboard so there isn't a middle mouse button but I found an option "Show Window Manager Menus on Desktop clicks" on the desktop menu. That then showed a totally different menu including "Desktops >" which included a "Add new desktop" option.
:D
But now the original menu has vanished. Hmmm.
