learning worksheet problem
Tue Dec 06, 2016 6:07 am
I've been following the instructions for this worksheet, and I'm having problems with the rain.
Every location I check (even places where it's been storming) the rainfall always comes back as 0. Is there a way to fix this?
Re: learning worksheet problem
Wed Dec 07, 2016 8:08 am
Try the Web interface http://openweathermap.org/city/2656192 (search for your own city) make sure their data is correct.
sudo pip3 install pyowm
Try this python3 program
import pyowm
owm = pyowm.OWM('ed2fredactedapikeyc500206b3fbde4')  # You MUST provide your valid API key
observation = owm.weather_at_place('Basingstoke,uk') ## CHANGE ME ##
weather = observation.get_weather()
rain = weather.get_rain()
wind = weather.get_wind()
humidity = weather.get_humidity()
temp = weather.get_temperature('celsius')
print ("Rain:", rain, " Wind:",  wind, " Humidity:",  humidity, "Temp:", temp)
Which isn't getting any sensible rain value for me. So the problem may exist with the OpenWeather API not with your Scratch program.
Run that with python3 myweather.py
You can test your API key with http://api.openweathermap.org/data/2.5/ ... 206b3fbde4 you will need to change that URL to use your API key not my redacted version.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
Return to “Beginners”
Who is online
Users browsing this forum: bob_binz, JMastaC4, Mahomat and 28 guests
