NetBeans install on RPi3
Posted: Wed Nov 23, 2016 12:47 pm
by RichInTheUSA
I have the latest version of noobs, and did the apt-get upgrade/update.... and went to the Add/Remove Software menu in the desktop UI.
I notice that when I search for NetBeans, it only lists NetBeans 7 (and not 8). Why doesnt v 8 show up?
Is there a preferred way to install the latest netbeans onto my Pi3?
Should I go to netbeans.org and download the platform independent package?? Or should I try with apt-get install? If the latter, what's the name of the package? (or how do I find it out?)
Thank you
Re: NetBeans install on RPi3
Posted: Wed Nov 23, 2016 9:36 pm
by RichInTheUSA
Well, I successfully downloaded and installed NetBeans on the RPi3... created a new project, wrote a hello world java application.
It took 33 minutes 42 seconds to build!! I then did a clean and build, which took 4 seconds.
Ok, this can't be normal. Should I expect better performance?
Posted: Wed Nov 23, 2016 9:55 pm
by fruitoftheloom
NoobS is an installer / chooser not an Operating System. :?
