dagu rover 5 help
Posted: Mon Nov 21, 2016 9:10 pm
by razatherogue
Can I cut wires on the Dagu Rover 5? I don't need the encoder wires (which I think are the thick ones, correct me if I'm wrong) so is it ok to cut them? Or should I leave them as is?
Also in the guide I am following the rover only has two motors but the one i have has 4? Please help
Re: dagu rover 5 help
Posted: Mon Nov 21, 2016 9:29 pm
by mikronauts
NO. Bad idea, as you will likely need them in the future. Just ignore the encoder leads.
There are two and four motor Rover 5's, I have both types, and I've never heard of a three motor one.
Post a link to your bot.
razatherogue wrote:Can I cut wires on the Dagu Rover 5? I don't need the encoder wires (which I think are the thick ones, correct me if I'm wrong) so is it ok to cut them? Or should I leave them as is?
Also in the guide I am following the rover only has two motors but the one i have has 3? Please help
Posted: Mon Nov 21, 2016 9:42 pm
by razatherogue
Posted: Mon Nov 21, 2016 9:57 pm
by mikronauts
Yep, I have a couple of those.
Don't cut the wires, you will later regret it.
Posted: Mon Nov 21, 2016 10:12 pm
by razatherogue
So which motors do I connect? My controller board only has 2 motor controllers, not 4.
Posted: Tue Nov 22, 2016 1:42 am
by mikronauts
Wire the two motors on each side in parallel.
Make sure the motors on each side go in the same direction (ie take the tracks of for testing)
Make sure your motor driver board can drive as much current as the two motors on each side need.
razatherogue wrote:So which motors do I connect? My controller board only has 2 motor controllers, not 4.
