rfeyer
RSYNC with DAY and MONTH in destination folder
Sat Nov 19, 2016 8:00 pm
I've been able to create a local mount with Dougie's help.
No I have been trying to automate a backup of RPi folders to the mounted Win Folder.
All is woring very well with static folder names, but I would like to have the RSYNC command use Month and Day in the folder names.
Here is what works:
rsync -a /home/pi/Projects /mnt/ThinkCentre/RPi/trialRPi_BU/Saturday
The folder Projects and it's content is being copied to the correct mounted folder trialRPi_BU and adds folder Saturday if it is not already present.
Now, I have been reading multiple examples using date, so, I made a bash script with the commands:
DATE=`date +%m.%d`
rsync -av /home/pi/Projects /mnt/ThinkCentre/RPi/trialRPi_BU/$DATE
This now copies origin folder Projects and content, but, adds the following to the destination folder trilRPi_BU:
folder name: DATE
and inside folder DATE, copies the appropriate folder Projects and it's content.
Why is DATE not recognized as a variable to be interpreted?
Re: RSYNC with DAY and MONTH in destination folder
Sat Nov 19, 2016 8:49 pm
Run your script with bash -x /home/pi/rsync.sh # or whatever its name is. That shows how each variable expands and should show what's going wrong.
This is a doctor free zone.
rfeyer
Sat Nov 19, 2016 9:11 pm
This is the output of the bash -x (as you can see, I added /usr/bin/date to see if it was a date retrical problem)
+ DAY0=''\''/usr/bin/date'\''/'
+ DAY1='/usr/bin/date -I -d "1 day ago"/'
+ SRC=/home/pi/Projects
+ TRG='/mnt/ThinkCentre/RPi/TrialRPi_BU/'\''/usr/bin/date'\''/'
+ OPT=-avhr
+ rsync -avhr /home/pi/Projects '/mnt/ThinkCentre/RPi/TrialRPi_BU/'\''/usr/bin/date'\''/'
sending incremental file list
rsync: mkdir "/mnt/ThinkCentre/RPi/TrialRPi_BU/'/usr/bin/date'" failed: No such file or directory (2)
rsync error: error in file IO (code 11) at main.c(674) [Receiver=3.1.1]
Dutch_Master
Sat Nov 19, 2016 9:21 pm
If you want the Bash shell to expand a command including another command, use back-ticks. These are usually on the same key as the tilde ~.
example:
#! /bin/bash
echo "Today is" `date`
HTH!
rfeyer
Sat Nov 19, 2016 9:26 pm
I made another small script, entered exactly as above echo "today is" 'date'
and received the following: Today is date
Sat Nov 19, 2016 9:46 pm
Dutch_Master wrote:If you want the Bash shell to expand a command including another command, use back-ticks. These are usually on the same key as the tilde ~.
Not on my keyboard, they aren't. (UK keyboard layout) ;-)
Also, the use of back ticks in bash is deprecated. They can get messy and confusing. The current recommendation is to use the $() construct for the command, which can have multiple levels.
Your example, but using $()
#! /bin/bash
echo "Today is" $(date)
although I would code that as
#! /bin/bash
echo "Today is $(date)"
rfeyer
Sat Nov 19, 2016 9:52 pm
Getting somewhere
So, echo "Today is" $(date) - TY!
Then I tried to get it into a variable:
noww= $(date +'%Y')
This gave the result: line 6: 2016: command not found
Sat Nov 19, 2016 9:56 pm
Get rid of the space after the =
It needs to be
noww=$(date +'%Y')
not
noww= $(date +'%Y')
There's no spaces on assignment in bash. T'is a real PITA but you'll get used to it.
rfeyer
Sat Nov 19, 2016 10:03 pm
I retract, it worked!
using:
BUyear=$(date +'%Y')
rsync -av //target /destination/$BUyear
worked
Thank you all again!!
Dutch_Master
Sat Nov 19, 2016 10:23 pm
rfeyer wrote:I made another small script, entered exactly as above echo "today is" 'date'
Because you used single quotes, not back-ticks.
@rpdom: I wasn't aware that back-ticks are now depreciated. They still work on mine.
bash --version
GNU bash, version 4.3.42(1)-release (x86_64-pc-linux-gnu)
(trunkated)
Sat Nov 19, 2016 10:35 pm
Dutch_Master wrote:@rpdom: I wasn't aware that back-ticks are now depreciated. They still work on mine.
bash --version
(trunkated)
I didn't say they didn't work, just that they are deprecated (the use of them is discouraged).
rfeyer
Sun Nov 20, 2016 6:17 pm
Sorry to say - after all your help I am still stuck.
Below are the bash file and error:
#!/bin/bash
toPath="/mnt/ThinkCentre/RPi/TrialRPi_BU/$(date +'%B')/$(date +'%d')"
#execute
rsync -rh /home/pi/Projects/ $toPath
error:
rsync: mkdir "/mnt/ThinkCentre/RPi/TrialRPi_BU/November/20" failed: No such file or directory (2)
Sun Nov 20, 2016 6:35 pm
rfeyer wrote:Sorry to say - after all your help I am still stuck.
#!/bin/bash
#execute
error:
That's because the destination directory doesn't exist.
Try this
#!/bin/bash
# Make sure destination directory exists
mkdir -p $toPath
#execute
Oh, just as an aside, you could just use one date command in that line by including the / in the date format string
toPath="/mnt/ThinkCentre/RPi/TrialRPi_BU/$(date +'%B/%d')"
or even
toPath="$(date +'/mnt/ThinkCentre/RPi/TrialRPi_BU/%B/%d')"
By just using the one date command you avoid the possibilities of strange issues if the script is run at certain times.
For example, if the script runs very, very close to midnight on 30th November. The first date command would return "November", but the second command will run a fraction of a second later and the clock could have ticked past midnight and return "01" as it is now 1st December. A very rare occurrence, but it could happen.
rfeyer
Sun Nov 20, 2016 6:59 pm
TY for the reply - tried it, but still does not work.
I am pasting below the code I used - first with the variables - even with mkdir $toPath it still refused.
Then, as you can see inside code, I used almost the same path in the toPath variable, without the dates, and it worked.
Also, I thought rsync would create paths which are not existent?
#!/bin/bash
#toPath=/mnt/ThinkCentre/RPi/TrialRPi_BU/$(date +'%B')/$(date +'%d')
#toPath="$(date +'/mnt/ThinkCentre/RPi/TrialRPi_BU/%B/%d')"
mkdir -p $toPath
toPath = "/mnt/ThinkCentre/RPi/TrialRPi_BU"
#execute
rfeyer
Sun Nov 20, 2016 7:04 pm
OK - I rebooted RPi and the below worked!!!!
TY all again, not sure how I will get these variables straight!
So, though, I still thought rsync would create the folders?
#!/bin/bash
mkdir -p $toPath
#execute
