Pramodh B
Xming for jessie lite
Thu Nov 17, 2016 4:52 am
can any one sujjest me the command to switch from putty terminal to raspbian jessie lite ,
lxsession not working
startx not work
lxde not work
lxde-pi not working
tell me the steps clearly
Re: Xming for jessie lite
Thu Nov 17, 2016 6:00 am
Pramodh B wrote:can any one sujjest me the command to switch from putty terminal to raspbian jessie lite ,
startx not work
lxde not work
lxde-pi not working
Jessie Lite does not include a Desktop Environment, it is Command Line only..
Pramodh B
Thu Nov 17, 2016 6:02 am
so which raspbian i should use
suggest me a link
Thu Nov 17, 2016 6:13 am
You can probably get a basic desktop running on Raspbian Lite by installing raspberrypi-ui-mods.
sudo apt-get update
sudo apt-get -y install raspberrypi-ui-mods
This will install the software needed for the desktop without installing all the extras that the standard Raspbian image includes.
You'll probably need to reboot after installing that and configure the Pi to boot to desktop, and you may need to install additional software depending on what you require.
Thu Nov 17, 2016 6:15 am
Pramodh B wrote:so which raspbian i should use
suggest me a link
Raspbian Jessie with Pixel includes RealVNC, see the Blog:
https://www.raspberrypi.org/blog/introducing-pixel
https://www.raspberrypi.org/downloads/raspbian
Pramodh B
Thu Nov 17, 2016 6:23 am
suggest me a link
Pramodh B
Thu Nov 17, 2016 6:24 am
rpdom wrote:You can probably get a basic desktop running on Raspbian Lite by installing raspberrypi-ui-mods.
sudo apt-get update
after these two lines
lxsession will work right
