nebulloyd
Auto copy any device that is plugged in via USB
Thu Nov 10, 2016 5:47 pm
I have a relatively simple idea and wondering if anyone has done it, or if it can be done. I would like to set up a RP to automatically copy the data stored on any device when it is plugged into the USB port. I guess the data would be stored on an SD card in the easiest instance.
I would need advice from the ground up. i.e what type of RP, what bits and pieces I need, code, play by play steps and anything else that would be helpful. It would also be cool if any superstar programmer knows a way to make it only copy new data rather that repeating data that may be still on the device from the previous copy (not essential).
For some context this is a low energy cost solution for clearing up space on a GPS device for long trips in the forest recording monkey behaviour. RP would be powered with a portable battery. Thanks for your time.
RPi 3B
Macbook Pro 2011
topguy
Re: Auto copy any device that is plugged in via USB
Fri Nov 11, 2016 10:37 am
It can be done.. I have seen threads here for doing the same thing but with images. Unfortunately I dont have a handy link to such a thread.
- It usually starts with "udev" rules that can be used to trigger a script when a device is inserted.
- Then its the work of the script to mount the drive, locate the files and copy them to a designated destination.
- a command like "rsync" can use "filenames", "modification date" or even "checksums" to avoid copying data already transferred.
nebulloyd
Fri Nov 11, 2016 10:42 am
Thank you very much for taking the time that is a great help to give me new directions to investigate. I would also like to copy images. Do you think that an rsync could also specify file type?
RPi 3B
Macbook Pro 2011
wildfire
Fri Nov 11, 2016 11:16 am
nebulloyd wrote:Do you think that an rsync could also specify file type?
That's one of rsyncs duties (to syncronise files), I suggest you
man rsync
from a terminal.
E8 85 A2 64 C9 64 81 94 64 81 95 64 89 84 89 96 A3
Still NF Shirls
nebulloyd
Sun Nov 13, 2016 2:42 pm
I've been troubleshooting some connection issues but now I am back on this problem. I have access to my RPi3B via a VNC (using ethernet to macbook pro).
Would you be able to break down the steps in doing setting up the automated file sync a little more? I am a first timer on a steep learning curve.
I used
lsusb
to get the info for my GPS which reads
Bus 001 Device 004: ID 091e:2459 Garmin International GPSmap 62/78 series
I now need to know how to:
1. make the udev rule
2. how to run the rsync script when the device is detected (to store certain files from GPS to preferrably a USB drive or otherwise the kernel mSD card)
3. Auto shutdown device with some kind of signal that it is complete
RPi 3B
Macbook Pro 2011
karrika
Sun Nov 13, 2016 6:35 pm
The first thing is to create the udev rule like /etc/udev/rules/99-usbcheck.rules
It could contain something like:
KERNEL!="sd[b-z]1", GOTO="usbcheck_end"
IMPORT{program}="/sbin/blkid -o udev -p %N"
ACTION=="add", ENV{mount_options}="relatime"
ACTION=="add", ENV{ID_FS_TYPE}=="vfat|ntfs", ENV{mount_options}="$env{mount_options},utf8,gid=100,umask=002"
ACTION=="add", \
 RUN+="/usr/local/bin/blink", \
 RUN+="/bin/mkdir -p /tmp/usb", \
 RUN+="/bin/chmod a+rwx /tmp/usb", \
 RUN+="/bin/mount -o $env{mount_options} /dev/%k /tmp/usb", \
 RUN+="/usr/local/bin/processusb" \
 RUN+="/usr/local/bin/light"
ACTION=="remove", RUN+="/bin/umount -l /tmp/usb", \
 RUN+="/bin/chmod a-w /tmp/usb", \
 RUN+="/usr/local/bin/dark"
LABEL="usbcheck_end"
Here you have three routines for blinking a LED:
/usr/local/bin/dark
You have to write these depending on where your LED is.
To do the copy this script will execute /usr/local/bin/processusb. You have to write that as well.
The processusb could contain a rsync command like below.
/usr/bin/rsync -rptuv --modify-window=1 --partial --force /tmp/usb/ /opt/USBcontent
The strange --modify-window=1 is needed because USB sticks using VFAT have a time resolution of 2s. This line tells Linux to ignore small errors in the timestamp +- 1s.
In the "remove" action you can also put the shutdown command if you want.
nebulloyd
Sun Nov 13, 2016 7:41 pm
A great reply, thanks for that!
ok so i made the file using
sudo nano /etc/udev/rules.d/71-garmingps.rules will that be ok?
I then subbed out 'usbcheck' for 'garmingps' in your code.
assuming that is all correct...
where do I put this command /usr/bin/rsync -rptuv --modify-window=1 --partial --force /tmp/usb/ /opt/USBcontent
RPi 3B
Macbook Pro 2011
karrika
Sun Nov 13, 2016 8:23 pm
The rsync goes into a file called /usr/local/bin/processusb
You also need to make this file executable and add a proper header in front of it like this:
#!/bin/bash
/bin/mount -o remount,async,noatime,norelatime /tmp/usb
sudo chmod +x /usr/local/bin/processusb
Working with udev stuff is not really for beginners. Try to experiment a little and understand the lines what they do. This is kind of advanced stuff.
nebulloyd
Sun Nov 13, 2016 9:43 pm
so..
Screen Shot 2016-11-13 at 9.36.40 pm.png (32.82 KiB) Viewed 4268 times
Screen Shot 2016-11-13 at 9.37.27 pm.png (27.07 KiB) Viewed 4268 times
like this?
Yes, I am definitely in over my head but happy to stick with it so long as people have patience :oops: thanks again for your time I really appreciate it
RPi 3B
Macbook Pro 2011
karrika
Mon Nov 14, 2016 5:01 am
Wow. Perhaps it would be good to start from very basics like how to enter a command on the console.
You can enter a command and separate it from its argument with a space.
cd/media
Does not separate the command from the argument.
cd /media
does separate the command from the argument.
Try to find the other similar errors in your previous post. The command "chmod" is used to change attribute bits on a file.
Typical attributes are
r = read
w = write
x = executable ( like a .bat file in Windows )
The command sudo is to gain super user power for executing the next command.
There is a lot more about access control. The obvious thing is that chmod was not part of the content of processusb. It was a command to change processusb to an executable script file.
topguy
Mon Nov 14, 2016 11:39 am
Based on previous experiences with udev, the "processusb" script should probably spawn off the rsync process in the background. The process will be killed by linux/systemd if it runs for too long (more than a few seconds). This was a problem for those who copied lot of imagefiles.
I would probably also have moved the mount commands and LED control also to a new script together with the rsync.
karrika
Tue Nov 15, 2016 8:34 am
My example is old before systemd and jessie.
You can run stuff in the background by surrounding the code with ( ) and adding a & after it.
  command1
  command2
Then the udev rule can exit immediately and the code keeps running in the background. This is a bad solution as you do not have control on what goes on. A better solution might be to create a service of the copying process and command it from the systemctl. But that is quite complicated.
Tue Nov 15, 2016 9:06 am
karrika wrote: A better solution might be to create a service of the copying process and command it from the systemctl. But that is quite complicated.
That's trivial with systemd.
sudo nano /etc/systemd/system/usbcopy.service
[Unit]
Description=Run usbcopy cmd
[Service]
ExecStart=/usr/local/bin/usbcopy.sh
StandardOutput=syslog
StandardError=syslog
SyslogIdentifier=usbcopy
Type=oneshot
Enable that with systemctl enable usbcopy.service
Start that with systemctl start usbcopy
nebulloyd
Wed Nov 16, 2016 8:52 pm
Thank you so much for your time in responding. I hope to meet up with someone from IT at my uni on Monday. I will post as much as I can remember about how she does it, I hope it can be done!
RPi 3B
Macbook Pro 2011
