BaldoBeardo
SD Card formatting using Pi
Tue Nov 08, 2016 7:34 pm
Hi all, apologies if this is answered elsewhere but I can't find it if it is!
Is there some way to format an SD card / install NOOBS on it using the Pi itself?
As in, plug a USB SD card reader into the Pi, insert fresh-out-the packet SD card into the reader and wind up with a card that would work for a Pi Zero?
NB. an additional card - obviously you'd need to already have an OS SD card in the Pi to do all this!
Total Pi beginner so apologies if there's something obvious I've missed.
Re: SD Card formatting using Pi
Wed Nov 09, 2016 7:29 am
BaldoBeardo wrote:Hi all, apologies if this is answered elsewhere but I can't find it if it is!
Follow instructions relating to Linux:
https://github.com/raspberrypi/noobs/bl ... /README.md
RPi 4B 4GB (SSD Boot)..
FTrevorGowen
Wed Nov 09, 2016 8:50 am
+1
However, if you don't need NOOBS' "multi-boot" option, ie. just require Raspbian you could use the Linux "image install" method - FWIW, screenshots & link to the main (RPF) instructions can be found here:**
http://www.cpmspectrepi.uk/raspberry_pi ... lPi3B.html
Trev.
** NB. I'd previously installed GParted on my P3B - that's not necessary for the install, but helps provide more (screenshot-based) info. w.r.t. the "underlying process".
BaldoBeardo
Wed Nov 09, 2016 8:45 pm
That's really helpful folks. Thanks!
