PeeWee
system-config-printer
Mon Sep 03, 2012 7:02 am
I have installed system-config-printer onto my Pi, but I am having installing my wifi Canon printer.
After opening system-config-printer, I click on add printer and follow the instructions to add my printer. The printer is located without a problem and the printer driver is found without a problem. The problem starts when the Authentication window opens.
The authentication window has the following message:
"Privileges are required to add/remove/edit a remote printer".
I enter pi as username and raspberry as password, but these are not accepted by system-config-printer.
I have also tried connecting to the printer using LX Terminal and sudo bash, then system-config-printer commands, but get the same result.
I do have CUPS installed and I have added pi as username to lpadmin by using the command "sudo usermod -a -G lpadmin pi".
Also, CUPS does not find my printer when I use use CUPS to install my printer, yet system-config-printer does find my printer (just will not let me install it).
Finally, system-config-printer does seem to add the printer after I have cancelled the installation, but I cannot print to it. However, I can delete the printer without any problem using the same authentication window that pops up during the install.
Any help would be appreciated.
PeeWee
Jehosophat
Re: system-config-printer
Mon Sep 17, 2012 12:14 pm
I have exactly the same password problem when trying to install my HP printer.
Sorry that I dont have a solution.
penguintutor
Mon Sep 17, 2012 7:16 pm
I haven't had much luck with printers. I believe it was a performe wance issue with the Raspberry Pi.
However I believe the permissions are set using lpadmin group.
When logged in - from a console (terminal) try
groups
See if you are in the "lpadmin" group
If not then how to add is detailed at: http://www.penguintutor.com/linux/useradmin-reference i wrote the guide to administrating users for Linux before the Raspberry Pi, but coincidently uses the lpadmin group in the example.
tualatinweb
Tue Sep 18, 2012 3:11 am
I'm also having an issue getting my HP Photosmart 6510 printer working with either system-config-printer or CUPS. Both are installed, however when I try and print a Test Page from within system-config-printer the Status shows "Stopped".
Test print with CUPS on the Midori browser shows a State of:
Stopped
"/usr/lib/cups/filter/foomatic-rip failed"
I'll pay $50 to get printing working through PayPal, thanks.
Daniel
Boomer
Tue Sep 18, 2012 9:51 pm
I'm currently trying to enable printers too. Found this link that might help:
Http://wiki.debian.org/SystemPrinting#HP. It's not limited to HP printers despite the title.
inkyfingers
Sun Sep 30, 2012 3:55 pm
sudo apt-get install foomatic-filters
might be worth a try
parann0yed
Thu Oct 25, 2012 5:17 am
If you're willing to pay, check out turboprint...http://www.turboprint.info/. You get a 30 day trial then the option to buy a license. It's not bad if you can't get your printer working by other means.
penguintutor
Thu Oct 25, 2012 11:31 am
Turboprint is a proprietary application provided as binaries.
For Linux it is available for Intel / AMD processors only and will not therefore run on the Raspberry Pi.
